Force between an infinitely long wire and a square loop
The discussion focuses on calculating the net force, F, on a square loop of wire carrying current I1, positioned a distance d from an infinitely long wire carrying current I2. The derived formula for the force is F = I1 * a * μ0 * I2 * ((1/2π(d - 0.5a)) - (1/2π(d + 0.5a))). Additionally, the magnetic moment, m, of the loop is defined as m = I * A, where A equals the area of the loop. The final expression for the force in terms of the magnetic moment is F = (m/a^2) * a * μ0 * I2 * ((1/2π(d - 0.5a)) - (1/2π(d + 0.5a))).
  • Understanding of electromagnetic theory, specifically Ampère's Law.
  • Familiarity with the concept of magnetic moment in current loops.
  • Knowledge of the Biot-Savart Law for calculating magnetic fields.
  • Basic algebra and calculus for manipulating equations.
  • Study the derivation of the Biot-Savart Law for magnetic fields around current-carrying conductors.
  • Learn about the applications of magnetic moments in various physical systems.
  • Explore the effects of varying distances on the force between current-carrying wires.
  • Investigate the implications of magnetic forces in electromagnetic devices.
Students and professionals in physics, electrical engineering, and anyone interested in the principles of electromagnetism and magnetic forces between current-carrying conductors.
xinlan
A square loop of wire with side length a carries a current I1 . The center of the loop is located a distance d from an infinite wire carrying a current I2. The infinite wire and loop are in the same plane; two sides of the square loop are parallel to the wire and two are perpendicular as shown.
1. What is the magnitude, F , of the net force on the loop?
I got that one, which is
F= I1*a*uo*I2*((1/2pi(d-0.5a)-(1/2pi(d+0.5a))
2. The magnetic moment m of a current loop is defined as the vector whose magnitude equals the area of the loop times the magnitude of the current flowing in it (m=IA), and whose direction is perpendicular to the plane in which the current flows. Find the magnitude, F , of the force on the loop from Part A in terms of the magnitude of its magnetic moment.
Express in terms of m,I2 ,a ,d , and uo .
since m=I/A, then I= m/A
F = (m/A)*a*uo*I2*((1/2pi(d-0.5a)-(1/2pi(d+0.5a))
Did I do it correct?
Thank you..
Get rid of the A. It equals a^2.
thank you Doc Al.. :)
