How Do You Calculate Refraction Index and Object Distance in Optics Problems?
  • Thread starter Thread starter Saturnfirefly
    Optics
The discussion focuses on calculating the index of refraction and object distance in optics problems. The critical angle for total internal reflection from a material to air is established as 54 degrees, which is used to derive the index of refraction using the formula sin(C) = n2/n1. Additionally, for a converging lens with a focal length of 20 cm, the object must be placed within the focal point to create a virtual image that is four times larger than the object, indicating a specific relationship between object and image distances.
  • Understanding of Snell's Law and critical angle calculations
  • Familiarity with lens formulas and magnification concepts
  • Knowledge of converging lens properties and focal lengths
  • Basic algebra for solving equations related to optics
  • Learn how to derive the index of refraction using sin(C) = 1/n
  • Study the lens formula: 1/f = 1/do + 1/di for converging lenses
  • Explore the concept of magnification in optics and its mathematical implications
  • Investigate the conditions for total internal reflection in different media
Students studying optics, physics educators, and anyone interested in understanding lens behavior and refraction principles.
Saturnfirefly
1. When light travels from a material to air, total reflection occurs beyond 54 degrees. Calculate the index of refraction.
2. A converging lens has a focal length of 20 cm. When an object is placed at a certain disctance from the lens, a virtual image is created. How far from the lens is the object placed if the height of the image is 4 times greater than the object?
1. sinC= n2/n1
2. ?
1. I can use the equation, but I don't know how to calculate(?) the critical angle. I don't think any calculating is neccesary. The critical angle should be 45 (I'm not totally sure) degrees, and my question is why?
2. I know that you have to place the object within the focal point to get a virtual image using a converging lens. And that tells us that the answer should be -something. But I don't know how to solve the equation... anyone that can by detail show me how to solve it? Answer should be di = -60
1) The critical angle is given. Use it to solve for the index of refraction.
2) If the image is 4x bigger than the object, what does that tell you about the ratio of object and image distances? (Look up magnification.)
the critical angle is 54 degrees, not 45, or am i missing something here?
use the formula for the critical angle to calculate the index of refraction(sin critical angle = 1/refraction index)
  • · Replies 16 ·
