Solving for Roots of a Polynomial Equation
  • Thread starter Thread starter transgalactic
The discussion revolves around solving for the roots of a polynomial equation, specifically focusing on the characteristic polynomial derived from a matrix. Participants are exploring the implications of the minimal polynomial and the relationships between the determinant and the roots.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss forming the characteristic polynomial from a matrix and question the validity of certain conclusions regarding minimal polynomials. There are attempts to factor polynomials and check for repeated roots, as well as inquiries about the implications of having terms in the denominator.
The discussion is ongoing, with various participants providing insights and questioning each other's reasoning. Some guidance has been offered regarding the formation of the characteristic polynomial and factoring, but no consensus has been reached on the interpretation of results or the next steps.
Participants are navigating constraints related to the properties of polynomials and matrices, including the implications of having a term in the denominator and the requirement to equalize coefficients. There is also a request for further clarification on a transformation question, indicating a desire for deeper understanding.
Just writing 'there is no minimal polynomial' isn't much of a try. Form the matrix M-x*I and take it's determinant to get the characteristic polynomial and then factor to see if there are repeated factors you can drop.
Having concluded, correctly, that MT is
[tex]\left[\begin{array}{cccc} 0 & 0 & 0 & 1 \\ 0 & 0 & 1 & 0 \\ 0 & 1 & 0 & 0 \\ 1 & 0 & 0 & 0 \end{array}\right][/tex]
How can you declare that MT v= 0? For all v? By the definition of M, M<1, 0, 0, 0>= <0, 0, 0, 1>. The only matrix that takes every vector to 0 is the 0 matrix! And every matrix except the 0 vector has a minimal polynomial. As Dick said, the characteristic polynomial is given by
[tex]\left|\begin{array}{cccc} -\lambda & 0 & 0 & 1 \\ 0 & -\lambda & 1 & 0 \\ 0 & 1 & -\lambda & 0 \\ 1 & 0 & 0 & -\lambda \end{array}\right|[/tex]
Take out any repeated factors to get the minimal polynomial.
You have [itex]\lambda^5- \lambda^2+ \lambda- 1[/itex] and then a arrow pointing to
[itex](\lambda^2- 1)(\lambda^3+ 1)/\lambda[/itex]. How did you go from the first to the second? Oh, and since the determinant you are evaluating only has 4 [itex]\lambda s[/itex] in it, how are you getting [itex]\lambda^5[/itex]?
i was looking for numbers which make the hole thing 0
i put 1 and -1
and then i get
L=lamda
(L-1)(L+1)(ax^3+bx^2+cx+d)
i opened the colls and equalized the coeffishents
and fount the a b c d
also i divided by L because i multiplied some line by L
so the determinant must be divided by L
what now??
and also can you please answer on my PM about the question
of the transformation
i really want to understand this thing from top to bottom
  • · Replies 18 ·
