What is the Range of Mass m2 to Keep the System Stationary on a Bended Plane?
  • Thread starter Thread starter Ivanperez
    Range
The discussion focuses on determining the range of mass m2 required to keep a system stationary on a bended plane, where block m1 has a mass of 2kg and friction coefficients of 0.3 (static) and 0.2 (kinetic). To maintain equilibrium, the forces acting on m1 must be balanced by the gravitational force acting on m2. The analysis involves creating free body diagrams and applying the principles of static friction to establish inequalities that define the acceptable range for m2.
  • Understanding of static and kinetic friction coefficients
  • Ability to create and interpret free body diagrams
  • Knowledge of Newton's laws of motion
  • Basic algebra for solving inequalities
  • Study the principles of static equilibrium in physics
  • Learn how to derive inequalities from free body diagrams
  • Explore the effects of different friction coefficients on motion
  • Investigate the application of Newton's laws in multi-body systems
Students of physics, engineers dealing with mechanics, and anyone interested in understanding forces on inclined planes and static equilibrium.
Ivanperez
In the showen figure the mass of block m1 is 2kg and the static and kinesthetic friction coefficients of this block with the bended plane are 0.3 and 0.2
If the system is in rest state,find the range of the values that m2 can take for the system not to move
http://img513.imageshack.us/img513/3113/fisfl9.png
I really don't know how to get in an inequality
If the system is not moving, that should give you a hint as to which friction coefficient to use. Note that if m2 is not heavy enough, then m1 will slide down the plane; if m2 is too heavy, m1 will slide up the plane. You've got to look at those 2 extremes to get a range. Draw good free body diagrams, and note carefully the direction of all the forces acting on each mass.
  • · Replies 25 ·
