| Thread Closed |
Rate of heat loss? Speed of heat. |
Share Thread | Thread Tools |
| Feb7-08, 11:18 AM | #1 |
I have some extended aluminum part which is at low temperatures. It is connected by a thin alu rod to a cooling device held at a constant temperature.
How can I estimate the rate of cooling through this thin rod given the material specific constants? I assume the heat exchange with the surrounding atmosphere is small, but wouldn't mind including it in my calculations. The Green function is a particle diffusion function. So can I associate the particle/heat speed somehow with a velocity that would give me the "speed of heat"? Then for 1D or 3D I'd calculate the "distance travelled by heat" keeping in mind some diffusion correction depending on the dimension?! |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Feb7-08, 01:24 PM | #2 |
| Feb7-08, 06:35 PM | #3 |
You can't associate any speed to diffusions such as Brownian motion, because of the way they scale under rescaling time.
| Feb7-08, 09:53 PM | #5 |
If we're talking about solids then the particles only vibrate. It is the phonons in the solid which transmit heat. I presume you could do something like radiative transfer but instead of light in a gas consider phonons in a solid, where the scattering would obay something like Beer's law.
| Feb7-08, 10:04 PM | #6 |
Equivalently, if f(t,x) is a solution of the heat equation, then so is [itex]f(a^2t,ax)[/itex], but velocities/speeds are not invariant under rescaling space & time like this, because velocity has units of length over time. Edit: that is, there is no fixed speed. I suppose you could define a speed v such that [itex]df/dt+v\cdot\nabla f=0[/itex], but it would depend on f. |
| Feb7-08, 10:19 PM | #7 |
What does brownian motion have to do with this problem? This is basic heat transfer via conduction and convection. Just set up a thermal resistance network and solve. Jeesh.
| Feb7-08, 10:23 PM | #8 |
| Feb7-08, 10:25 PM | #9 |
I think hes trying to use that because it mentions particle speed, to somehow relate it to heat speed, when all he has to do is look at the heat transfer rate.
I could be wrong though. I read it as a solid aluminum bar being cooled on one end. No particle motions are necessary. |
| Feb7-08, 10:38 PM | #10 |
| Feb7-08, 10:48 PM | #11 |
Isn't Brownian motion just a random walk? Was is that relevant to heat transfer given that energy is exchanged between particles?
| Feb7-08, 10:48 PM | #12 |
If you have [itex] d^2f/dt^2=k\nabla^2 f[/itex], as in the wave equation, then k has units of velocity^2. In the heat equation you have [itex]df/dt=k\nabla^2 f[/itex] and k has units of length^2/time. |
| Feb7-08, 10:58 PM | #13 |
| Feb7-08, 11:04 PM | #14 |
Mentor
To the first order this is a simple problem in conduction, You need the thermal properties, cross sectional areas and the lengths of your various components. If you set up the more complex methods mentioned, which could be done, your solution will be very nearly the conduction equation.
Unless there is a large temperature difference to the atmosphere or you are blowing air across the surfaces, convective and radiative losses will be small to negligible. |
| Feb8-08, 05:06 AM | #15 |
| Feb8-08, 06:16 AM | #16 |
I tried to solve the problem and assumed that the heat spreads instantly in this alu block and that along the rod there is always a constant gradient. I get an exponential solution for the temperature of the alu block. [tex]T=A+Be^{-kt}[/tex] Are these approximations OK? |
| Feb8-08, 10:56 AM | #17 |
You can find the solution of the differential equation for this problem in any heat transfer book. all you need to do is to put your numbers and you have the answer. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Rate of heat loss? Speed of heat.
| Rate of heat loss with two thermal conductivity values | Advanced Physics Homework | 7 | ||
| Rate of heat loss? | Classical Physics | 4 | ||
| On rate of heat loss 2 | Introductory Physics Homework | 2 | ||
| More on rate of heat loss | Introductory Physics Homework | 2 | ||
| Rate of Heat Loss | Introductory Physics Homework | 7 | ||
