Matlab iteration issue (I think :P)
  • Context: MATLAB
  • Thread starter Thread starter roesbak
    Matlab
The discussion revolves around a MATLAB coding issue related to a project on "Multiphase Flow in Pipes." The participant is attempting to simulate pressure changes in a vertical pipe with air injected at the bottom and is encountering problems with the iteration in their code, specifically regarding the pressure drop calculations.
  • Debugging
  • André describes the setup of a simulation involving pressure changes in a pipe, detailing the assumptions made about the fluid dynamics and the parameters used in the code.
  • André expresses concern that the pressure drop calculated in the loop appears constant, regardless of variations in the mass flow rate (m) and liquid flow rate (QL).
  • One participant suggests that a specific question would help in providing assistance and shares the basic syntax for MATLAB for loops.
  • André reiterates the problem, questioning whether the variable "pfrict" updates correctly within the loop and noting that the results do not vary as expected.
  • A later reply recommends saving all variables at each time step for debugging purposes, suggesting that this could help identify where the issue lies in the calculations.
Participants do not reach a consensus on the specific cause of the issue, and multiple perspectives on debugging strategies are presented. The discussion remains unresolved regarding the exact nature of the problem in the MATLAB code.
There is uncertainty regarding the correct updating of variables within the loop, and the impact of the defined parameters on the simulation results is not fully explored. The discussion highlights potential debugging techniques but does not resolve the underlying coding issue.
roesbak
Hi there,
I am working on a project in a subject called "Multiphase Flow in Pipes." We are to make a "simulator", describing the pressure (step-wise) in a pipe inserted vertically into water. Air is injected at the bottom of the pipe with a given mass rate, m, and for simplicity, ideal gas, no slip conditions, and a given QL (liquid flow rate) are assumed. The pressure-losses taken into account are hydrostatic and friction only. (I can explain further on request, but my problem is, I hope, code-related, and not physics :P)
I started writing what I thought was a fairly simple piece of "code", and decided to test my program with one given m and QL. However, based on my graph, it looks as though the pressure-drop upwards in the pipe is constant, and does not change, no matter what m and QL I try.
I think I may have done something wrong in my "for" loop, but since I am very inexperienced with Matlab, I thought I would ask if anyone might give me a small pointer..
Code follows:
clf
% First, we set up the main constants
g = 9.81;
h = 50;
D = 0.15;
rhoL = 1000;
P(1) = 1*10^5 + (rhoL*h*g);
Ptop = 1.013*10^5;
Pref = 1.013*10^5;
nu = 1.5*10^-5;
viscL = 0.001;
rhoref = 1.2;
% Then we start entering the equations necessary to iterate.
dH = 0.5;
H = 0:dH:h;
NH = length(H);
m = 1;
ql = 0.001;
for i = 2:NH % Loop, upwards in the well.
% Calculate gas density and friction pressure drop
rhoG = rhoref * (P(i-1)/Pref); % density of gas
qg = (m/rhoG); % volumetric flow rate of gas
EG = (qg)/(qg + ql); % gas fraction
EL = (ql)/(qg + ql); % liquid fraction
rhom = (EL * rhoL) + (EG * rhoG); % density of gas/liquid mixture
viscm = (EL * viscL) + (EG * rhoG * nu); % viscosity of gas/liquid mixture
U = (ql+qg)/((pi/4)*D^2); % flow speed
phyd = rhom * g; % hydrostatic pressure loss
pfrict = (4/D) * 0.046 * ((rhom*U*D)/(viscm))^(-0.2); % frictional pressure loss
ptot = phyd + pfrict; % total pressure loss
P(i) = P(i-1) - (ptot*dH)
end
figure(1)
plot(H,P)
Thank you very much for your time.
Yours
André Røsbak
Can you ask a specific question, I don't really feel like looking through all your code. I'm sure I can help if you ask a question pertaining to MATLAB though.
Maybe someone else will look through it though.
However, since you were talking about for loops. The syntax is
for i=a:h:b
end
a=start value
b=end value
h="step size"
so...
for i=1:1:3
i
end
would print:
and,
for i=1:0.5:2
i
end
would print,
Thank you for your reply.
I understand that you don't want to look at all of it, but I thought I should include it at least.
My question/problem is: My loop does not seem to be working. I think the problem is that my variable "pfrict" does not update itself for each step. Have I done something wrong when defining "prfict"? (i.e. does it "update" itself for each step, based on what I've written)
The graph I get is linear, i.e. the amount subtracted from the original pressure is the same, or at least veeeery similar, for each time step. This should not be the case. The results should at the very least vary for different m and QL inputs (defined in the lines just above where the for loop starts), but it does not.
Thank you.
- André
For debugging purposes you should save all your variables at each time step. E.g.
pfrict(i) = (4/D) * 0.046 * ((rhom(i)*U(i)*D)/(viscm(i)))^(-0.2);
That makes it much easier to trace backwards and find where the problem is coming from.
  • · Replies 45 ·
  • · Replies 20 ·
12K
  • · Replies 21 ·
  • · Replies 27 ·
