How Do You Calculate Speed and Acceleration in Curvilinear Motion?
The discussion revolves around calculating speed and acceleration in curvilinear motion, specifically for a truck traveling along a circular road. The original poster is attempting to determine the speed and acceleration magnitude at a specific distance, given an initial speed and a tangential acceleration that varies with distance.
  • Participants discuss the use of integration to find the final speed, with the original poster expressing confusion about the correct application of integration with respect to displacement. There are questions about whether to add initial velocity to the result of the integration.
Some participants have offered guidance on the integration process and clarified misconceptions about adding initial velocity to the final result. There is ongoing exploration of different interpretations of the integration results and the relationship between initial and final velocities.
The original poster mentions a lack of familiarity with integrating with respect to displacement, and there are indications of confusion regarding the definitions and relationships between velocity and acceleration in this context.
chrsr34
Hi guys,Im Chris, I am new here. I am in Dynamics doing curvilinear motion.
A truck travels at a speed of 4m/s along a circular road with radius if 50m. For a short distance, from s=0, its speed is then increased by a(tan) = (0.05s) m/s, where s is in meters. Determine the speed and acceleration magnitude at s=10. (i can find the a-magnitude easily after i find v, i just can't find v)
acceleration and velocity equations
a(tan)ds = v dv
Ive tried to attempt this using integration with respect to s, but this does not yield the correct answer, so its the incorrect procedure. The answer is 4.58 m/s.
I have never seen or dealt with integration with respect to displacement, therefore i don't know how to approach this problem. The book says nothing on figuring this out. Any help is appreciated, Thanks!
Chris
Hello, and welcome to PF!
Integration is indeed the way to go, so you must have made an error there. Let's see what you did, and then we can help you.
Thank you! well i integrated and got v = 0.025s^2, s = 10. This yeilds 2.5 m/s. Adding this to the initial 4 m/s yields 6.5 m/s. This is incorrect. the answer is 4.58 m/s. So, where is my error? I am quite dumbfounded...
Im starting to think this should be in advanced physics as it requires perhaps some difficult manipulation? I am in calc 3 and have no idea what to do...
To the Moderator, please move if you feel fit
You can not add the initial velocity. From the integration you have
[tex]\int_4^{v_f} v\,d\,v=\int_0^{s_f}\frac{s}{20}d\,s\Rightarrow \frac{1}{2}\,v^2\Big|_4^{v_f}=\frac{1}{40}\,s^2_f \Rightarrow u_f^2-4^2=\frac{1}{20}\,s_f^2[/tex]
Plug your values in the above equation to find the answer.
wow,i did not even think about integrating the v from 4-vf. Thank you so much. But just to be clear, you say that i can't add the initial velocity. The final answer of that integration is .58m/s so that would conclude that I do have to add the initial 4 m/s to get 4.58m/s. Isnt this correct?
Which integration? :confused:
If the initial velocity is [itex]v_i[/itex] then the final velocity is [itex]v_[/itex] then
[tex]v_f^2=v_i^2+\frac{1}{20}\,s^2\Rightarrow v_f=\sqrt{v_i^2+\frac{1}{20}\,s^2}[/tex]
The final velocity is not proportional to the initial velocity. That's why you can not add it.
Is it clear? :smile:
Hmm, now I am even more confused. Plugging s and vi into that equation gives me 6.4 m/s = vf. I don't understand, if the initial vi is 4m/s, and then accelerates for 10m to a new vf, wouldn't you be adding vi + delta v to get final velocity?
[tex]u_f^2-4^2=\frac{1}{20}\,s_f^2[/tex] solving for uf yields .58
adding 4+.58 yeilds the correct answer
How did you find [itex]v_f=6.4\,m/sec[/itex]? For [itex]s=10\,m,\,v_i=4\,m/sec[/itex] you get
[tex]v_f=\sqrt{16+\frac{100}{20}}\Rightarrow v_f=\sqrt{21}\Rightarrow v_f=4.58\,m/sec[/tex]
The definition of the acceleration is [itex]a=\frac{d\,v}{d\,t}\Rightarrow d\,v=a\,d\,t\Rightarrow v_f-v_i=\int_0^{t_f}a\,d\,t[/itex]. If you call [itex]\Delta v=\int_0^{t_f}a\,d\,t[/itex] then of course you can write [itex]v_f=v_i+\Delta v[/itex].
oh yes, your right, i was squaring the 100/20 by accident. I still don't fully understand the entire process but ill try and figure it out. Thanks again Rainbow Child.
