| Thread Closed |
Appropriate Concepts in the Formulation of Quantum Mechanics |
Share Thread | Thread Tools |
| Feb12-08, 10:26 AM | #1 |
It is clear that the concepts of position and momentum are idealizations from our macroscopic experience which are not appropriate in the quantum domain. Yet, in the presentations of elementary quantum mechanics I've seen so far, they are still used in a fundamental way. But obviously, they will be nothing like the position and momentum we know and therefore will seem "counterintuitive". What I'm trying to get at is that this counterintuitiveness is just an illusion, because we have no intuition about the quantum world that it can be "counter" to. This arises from the bad decision use the same names of "position" and "momentum" for something completely different and more fundamental.
The standard presentations give the idea that objects in the quantum domain still have the properties of position and momentum except that they are nothing like the ones we know. I think this is a bad way of saying it and leads to a lot of confusion. A better way is to say that position and momentum are approximate concepts valid in the large scale which arise from more fundamental concepts/concept ( which shouldnt be called by the same names ) valid at all scales, as far as we know. An analogy with special relativity make this clearer. Before SR, the concepts of absolute spatial and temporal seperations were used in the description of motion. What special relativity taught us was that these concepts are valid at low velocities but are just approximations to a more fundamental entitiy called the spacetime interval. But we still sometimes think about special relativity by retaining our our old concepts and using the "counterintuitve" rules such as the lorentz transformations. The language of events and invariant spacetime intervals is clearly superior to the language of lengths, time intervals and transformations. What I want to know is if there is an analogous viewpoint in Quantum Mechanics which uses more appropriate concepts for its formulation? If there is, I would be grateful if you can provide some references. FYI, I'm a first year undergraduate, so if you think it will be too technical for me at this stage, you can tell me that. |
| Feb12-08, 01:36 PM | #2 |
| Feb12-08, 02:25 PM | #3 |
We can think of this as a sort of relativistic comlementarity. depending on relative velocities, the seperation between two events can manifest itself in a more spacelike way or in a more timelike way, or equally. The space and time intervals are complementary components of the more fundamental spacetime interval. What about complementarity in quantum mechanics? Wave-like and particle-like behavior are complementary. Is there a unifying analogue of the spacetime interval in this case? I also have another question about quantum mechanical amplitudes. In the double-slit experiment, we have an amplitude that the electron will go to any particular point on the screen. But actually, the amplitude is only for the event that the electron will interact with a particular point of the screen and produce a dot on that screen. And this is actually the amplitude that we detect the dot at that particular point when we shine photons on it. This presupposes that we can treat the screen classically and that looking at the screen wont disturb the location of the dot. So whenever we give the amplitude as a function of time and position, we are actually presupposing that there is some substratum that can be treated classically, and the interaction of the particle with the substratum can be precisely located without disturbing it. Am I wrong? |
| Feb13-08, 12:29 AM | #4 |
I'm not entirely sure I got your main point, but I think you were basically reflecting over the choice of variables, and parametrization in quantum mechanics?
That's an interesting reflection. In relativity one has a global observer-invariant view, which is observer invariant. And to get the view of a particular observer, in a particular frame of reference one has to define the reference frame. The question is what is more fundamental, the observer-invariant view that relates the views of different observers, or the observer specific view? This is IMO one of the clashes between QM and classical mechanics, and I this may also relate to various interpretations. When we are going to "quantize" this, what set of variables are we to choose? If we consider that quantum mechanics supposedly delas with the observers information about it's environment, I am leaning towards that the quantization should be done in the observer view, not the birds view. But then of course the procedure may not be observer-invariant, but the question is if this is a problem? Maybe the loss of that invariance need to recovered with another symmetry, possibly even an emergent one, rather than fundamentally exact. Who knows? Although SR and QM are considered reasonably unified, that's still just a special case and GR remains. So perhaps there is not yet and universally accepted answer to your question? /Fredrik |
| Feb13-08, 01:43 AM | #5 |
/Fredrik |
| Feb13-08, 05:15 AM | #6 |
In quantum mechanics, we have the concepts of momentum and position. They dont mean the same thing that they meant in classical mechanics. This is because we have found that the exact measurement of position is impossible even in principle. There is no such thing as a classical-position. It is an approximation to another more fundamental concept which again we have chosen to call position. The same goes for momentum. These quantum mechanical versions of position and momentum form a conjugate pair. Heisenberg's uncertainty relation connects the uncertainties in these two variables. There is a similar "complementarity" between space-interval and time-interval in relativity, i.e. one depends on the other. They complement eachother in the sense that a particular combination of them called the spacetime interval is invariant. These "conjugate" quantities can be different for different observers but there is something more fundamental that is the same. Is there some similar concept for conjugate pairs in quantum mechanics and for wave-particle duality in general? I'm not saying there should be, I'm just wondering if there is. |
| Feb13-08, 05:35 AM | #7 |
Another difference between quantum mechanics and classical mechanics is that position and momentum are independent parts of the dynamical state in classical mechanics, while momentum states are superpositions of position states and vice versa in quantum mechanics. It is because of *this* property that we cannot simultaneously measure position and momentum, because a single value for one automatically means: a whole superposition for the other. But the concepts themselves, of position (and correspondingly precise position states), and of momentum (and correspondingly precise momentum states) are not altered by quantum theory. |
| Feb13-08, 07:24 AM | #8 |
| Feb13-08, 07:48 AM | #9 |
Again, quantum theory distinguishes itself from classical theory in that a quantum object can be (will be) in a superposition of different "classical" states. This means that one cannot, at that moment, assign ONE SINGLE classical state to such a quantum object. In this case, the single classical state is "position", and a quantum particle can be in a superposition of position states. That means then that we cannot assign a single position to that particle (but rather, "many in parallel", although the right word is not "parallel" but "in superposition"). This doesn't mean that the concept of "position" itself has become fuzzy ! It simply means that our system (particle) is in a superposition of positions. |
| Feb13-08, 07:53 AM | #10 |
I take it this is patly a philosophical question, so here goes some reflections without claim that it's standard reflections.
In QM, the notion of adding information about position and information about momentum has a special meaning. The reason one can not have arbitrary information about both in combination is because there by definition of momentum exists a relation between the two. This is of course also expressed via the commutator of q and p. In QM, the information about the system by postulate makes up a linear vector space. And the information is abstractly represented by a vector. Maybe this state vector is the "invariant" object you are looking for? Different questions/measurements is represented by projecting the state vector onto other vectors. But once a measurement is actually made, the state vector itself changes. This is why it seems like the state vector itself, really isn't objective after all, but these discussions relates partly also to the interpretational issues of QM. IMO, the plausability in non-commuting observables, is that in general there is no a priori reason to assume that information is independent of each other, I find it more "natural" to say that "you don't know". If you add two chunks of "information" it may well be that they are in contradiction, and then a rule for "making the addition" is needed so as to come out with a single consistent "piece of information" (a new state vector in QM). And it should not be unexpected that the order of addition matters. I may misundestand you still, but maybe you are after some idea that there must only be one reality, and how can the different views, giving different information, be understood in a general way? Maybe a difference is that in classical mechanics knowledge (answers) has some absolute meaning in some sense, although still relational, like in relativity. In quantum mechanics, knowledge (~answers) depends on the questions you ask - ie your choice of measurement. But still, in a certain sense there is a objective background info in QM, that is supposedly contained in the state vector. So that different questions giving different possible answers, still relates back to the one and same state vector. But there is a difference between considering different possible expected answers, and actually actually firing a question, because once it's fired and you get back the answer your state of information is by definition perturbed. Apart from this, maybe there is no such similar concept, or I don't understand your question. I see two reflections of objective/invariant and subjective in QM, and i'm not sure if they touch your issue, this is my personal thinking so don't take my word for it... 1) The state vector itself is relative to the questioner, or to the questioners information or knowledge. And thus is not _known_ to be observer invariant IMO in the general sense. But that doesn't prevent us from guessing an beeing lucky. And after some training it may not be a conincidence that we keep getting lucky ;) 2) The possible answers, any given questioner can fire, yields a spectrum of possible answers. And the possible expected answers to the possible questions is invariant with respect to different measurements, in the sense that they relate to the statevector. But as soon as a measurement is actually made, the questioners state (his information) is changed, to technically thes recently "informed" questioner is different that the old uninformed one :) This I mean in the sense of Zurek: What the observer knows is inseparable from what the observer is. The physical nature of the observer, is nothing but a manifestation or encoding of his information about his environment. /Fredrik |
| Feb13-08, 08:13 AM | #11 |
What is correct, however, is that we can, FAPP (for all practical purposes) now consider the vector to be projected on the outcome of the measurement, and that all further results obtained from there onward will be correct. |
| Feb13-08, 08:13 AM | #12 |
| Feb13-08, 08:17 AM | #13 |
/Fredrik |
| Feb13-08, 12:41 PM | #14 |
Regards. |
| Feb13-08, 01:41 PM | #15 |
| Feb13-08, 01:44 PM | #16 |
| Feb14-08, 12:32 AM | #17 |
You will form your own understanding when you take the first QM course. As is clear from the many threads on here, different people interpret things differently.
I'd say that the first conceptual difference to face is that (1) in classical mechanics the state of the systems, is objective and evolves deterministically. Given initial conditions all future states are determined. (2) In quantum mechanics, the new state of the system we consider, is really better interpreted as the state of our(the observers) information about the underlying system. And the evolution of the state vector is still deterministic in quantum mechanics! It's just that this describes the "selfevolution" of our state of information about the system - in between measurements. Given initial information, all future states of information are determined, or rather, all future spectrum of answers for possible questions are determined. BUT, as soon as a mesaurement is MADE, then you have reset your "initial state" to the updated information. Also the observer in QM, does not refer to humans or consicoussness. It just notes that information is relative. In principle one can imagine the observer to be an electron, observing the atom nucleus and the innner shells. This is the deeper stuff that you probably were after. But IMHO, there is still some lacking bits to make this entirely consistent in the general case. But I dont think that will become apparent during the first QM course either. It didn't for me at least. The indeterminism of the underlying system, althought the state vector evolves deterministically, is because the information we have about the system is incomplete. The fact that we have information about someting, does not mean we know everything. And this is in QM not just a practical matter, it's because questions in general doesn't commute. A way of interpreting that is to say that the two non-commuting questions are in part contradiction. ie you are trying to do two partly competing things at once. But why nature behaves like this, is still given different interpretations and somewhat open. And although the calculational scheme of QM is overly successful, there are problems in the big picture. /Fredrik |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Appropriate Concepts in the Formulation of Quantum Mechanics
| Path integral formulation of Bohmian mechanics... | Quantum Physics | 1 | ||
| Equivalence between path integral formulation and matrix formulation | Quantum Physics | 1 | ||
| [SOLVED] Re: equivalence between path integral formulation and other QM formulation | General Physics | 4 | ||
| Two concepts about quantum electrodynamics and quantum field theory | Quantum Physics | 16 | ||
