Projectile motion and time [SOLVED]
The discussion focuses on solving a projectile motion problem involving a cork expelled from a champagne bottle opened in a rising hot air balloon. The cork is expelled horizontally at 5.00 m/s while the balloon ascends at 2.00 m/s from an initial height of 6.00 m. The key equations used include those for calculating the cork's initial velocity, maximum height, and time of flight. The final solution involves using kinematic equations to determine the total time the cork remains in the air, accounting for both its upward motion and subsequent descent. The participant expresses gratitude for the assistance received in clarifying the solution process.
annersmarie
[SOLVED] Projectile motion and time
A hot air balloon rises from the ground with a velocity of (2.00 m/s) in the y direction. A champagne bottle is opened to celebrate takeoff, expelling the cork horizontally with a velocity of (5.00 m/s) in the x direction, relative to the balloon. When opened, the bottle is 6.00 m above the ground.
How long does the cork remain in the air?
There are other parts of this problem that I've already solved. For example, I've found that the initial velocity and direction of the cork, as seen by an observer on the ground, is 5.39 m/s at 21.8 degrees above horizontal (w/ respect to the balloon) with these equations:
V= [(5.0)^2+(2.0)^2]^1/2
theta= arctan (2.0/5.0)
I've also found that the maximum height above the ground attained by the cork is 6.204 meters by finding:
h= [(5.39^2)sin^2(21.8)]/2(9.81)
and adding it to the initial height of 6.00 m.
I know that the equation to find the time that a projectile is in the air is as follows:
t= [2Vo*sin(theta)]/g
but I know that that only accounts for the time that it will take the cork to reach a height of 6 meters. What I don't know is how to account for the rest of the time.
Forget about the corks velocity in the x direction, all you need to know is the vertical. The question tells you that the cork is moving 2 m/s upward and starts off 6m above the ground.
From there you can use constant acceleration formula to determine what the maximum height of the cork is and how long it takes to get there, and then how long it takes to fall to the ground again.
Welcome to PF,
I'm not checking your math, but your method looks good to me. For the time of flight, forget your time equation there and consider one of the general kinematic equations (found https://www.physicsforums.com/showpost.php?p=905663&postcount=2"). You know the initial displacement, the initial velocity as well as the final displacement, so which equation do you think you should use?
I guess it would be the displacement and time equation with uniform acceleration, just in the y dimension instead of the x. I'll get back with you after I do the math to see if I've got this figured out.
Thanks so far, guys.
Finished
Awesome. It was that equation after all. I actually tried it before I posted the first time, but I think my math was off somewhere when I used the quadratic formula to solve for t. Then I just ended up overcomplicating things for myself. Sometimes you're your own worst enemy, y'know?
Thanks again for the help. I really appreciate it.
-Anne
I know the feeling :rolleyes:
-Anne
A pleasure :smile:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
