Force Required to Move Box of Mass 20 kg w/ Friction
  • Thread starter Thread starter StephenDoty
    Force Mass
The discussion centers on calculating the force required to move a box of mass 20 kg on a horizontal surface with friction. The coefficients of static and kinetic friction are 0.50 and 0.30, respectively. The total mass of the system, including an additional box of 20 kg, leads to a static friction force of 196 N. To initiate movement, a weight of 98 kg must be added to the hook, as derived from the equation W = μs*m*g, where μs is the coefficient of static friction.
  • Understanding of Newton's laws of motion
  • Knowledge of static and kinetic friction coefficients
  • Familiarity with basic physics equations, specifically Fnet = ma
  • Ability to calculate normal force and frictional force
  • Study the principles of static and kinetic friction in detail
  • Learn how to apply Newton's laws to different physical systems
  • Explore the effects of different surface materials on friction coefficients
  • Investigate pulley systems and their applications in physics problems
Students in physics, engineers working with mechanical systems, and anyone interested in understanding the dynamics of friction and motion in practical applications.
StephenDoty
A box (m = 20 kg) is sitting on a horizontal surface. It is connected to a massless hook
by a light string passing over a massless pulley wheel. The coefficients of friction
between the box and the surface are 0.50 (static) and 0.30 (kinetic). On top of m is a
second box M of mass 20 kg. The coefficients of friction between the boxes m and M
are 0.80 (static) and 0.60 (kinetic). How much weight needs to be added to the hook
until the box just begins to move.
A) 10 kg B) 98 kg C) 20 kg D) 16 kg E) 200 kg
So the total mass of m= 40kg
so fs=40*9.80*.5
so fs= 196N
thus the force pulling down on the second mass has to equal fs
the force pulling down is mg
so mg=196N
m=20kg
I do realize that on the second mass hanging over the table has both a tension force and a mg force, do you have to take the tension into account? I wouldn't think so because we are trying to figure out how much mass is need to start the first mass moving, so the tension doesn't matter, its just the force that carries the mg force from the second mass to the first mass. Making mg=fs
Isnt the force of the system = 0 before it starts moving thus 0= mg -fs or mg=fs?
I do not like my way of solving this problem. How would you guys solve it??
Thanks
Stephen
Yes, your approach is correct. You can solve this problem by using the equation Fnet = ma, where Fnet is the net force acting on the box m, m is the mass of the box, and a is the acceleration of the box (which is zero since it is not moving). This equation can be rearranged to solve for Fnet: Fnet = ma = m*0 = 0. Since the net force is equal to zero, all the forces acting on the box must be balanced. The two forces acting on the box are the force due to gravity (mg) and the force of friction (fs). Therefore, mg = fs. To find the amount of weight that needs to be added to the hook, you need to calculate the force of friction. The force of friction is given by fs = μs*N, where μs is the coefficient of static friction between the box and the surface, and N is the normal force. The normal force is equal to mg, so fs = μs*mg = μs*m*g. Thus, the amount of weight that needs to be added to the hook until the box just begins to move is: W = μs*m*g = 0.5*20*9.8 = 98 kg.
  • · Replies 17 ·
  • · Replies 16 ·
9K
