HELP with current in loops and solenoids
  • Thread starter Thread starter BuBbLeS01
    Current Loops
The discussion focuses on calculating the diameter of a coil made from a 1.1-meter-long copper wire that generates a 1.66 mT magnetic field at its center with a current of 1.01 A. The user initially applies the formula LB/UI = N, where U is the permeability of free space (1.257 x 10^-6 H/m), resulting in approximately 1438.28 turns. The user seeks further guidance on how to proceed with the calculation after determining the number of turns.
  • Understanding of electromagnetic theory, specifically solenoids and magnetic fields.
  • Familiarity with the formula for calculating the number of turns in a solenoid.
  • Knowledge of the permeability of free space and its significance in magnetic field calculations.
  • Basic algebra skills for manipulating equations and solving for unknowns.
  • Calculate the radius of the coil using the formula for the magnetic field of a solenoid: B = (μ₀ * N * I) / L.
  • Determine the diameter of the coil from the radius calculated in the previous step.
  • Research the properties of copper wire and its resistance to understand its impact on current flow.
  • Explore the effects of varying the number of turns on the magnetic field strength in solenoids.
Students in physics or engineering courses, educators teaching electromagnetism, and hobbyists interested in building electromagnetic devices.
BuBbLeS01
You have a 1.1-m-long copper wire.You want to make an N-turn current loop that generates a 1.66 mT magnetic field at the center when the current is 1.01 A. You must use the entire wire. What will be the diameter of your coil?
I figured that this is a solenoid so I tried starting off by finding the number of turns it would take by using this equation...
LB/UI = N
The U is Mue 1.257x10^-6
I got 1438.28
but now I don't know what to do?
does anyone know what to do for this problem?
