Constructing a Table. (Radioactivity)
  • Context: Undergrad
  • Thread starter Thread starter _Mayday_
    Radioactivity Table
The discussion focuses on constructing a table to analyze how the count rate on a Geiger-Muller counter varies with distance from a radioactive isotope. Key table headings proposed include Distance (cm), Count Rate (or Activity), Background Count, and Corrected Count Rate. The inverse square law is highlighted as a critical concept, with a suggestion to incorporate the formula \(\frac{1}{d^2}\) to measure intensity variations. The goal is to test if the entries of d² times intensity remain constant across varying distances.
  • Understanding of Geiger-Muller counter operation
  • Familiarity with radioactive isotopes and their measurement
  • Knowledge of the inverse square law in physics
  • Basic mathematical skills for data analysis
  • Research the application of the inverse square law in radiation measurement
  • Learn how to calculate and interpret background radiation levels
  • Explore data analysis techniques for comparing count rates
  • Investigate methods for correcting count rates in radiation experiments
This discussion is beneficial for physics students, researchers in radiation measurement, and anyone involved in experimental design related to radioactivity and Geiger-Muller counters.
_Mayday_
NOTE: This is not homework, but if you feel it is in the wrong forum then move it. I didn't know a better forum that it could go in.
I want to construct a table of results (minus the results for now) that is related to how the count rate on a geiger muller counter varies with distance with a radioactive isotope. I would appreciate some suggestions of table headings. Here are a few I have already come up with, any thing you think I could add?
Distance/cm
Count Rate (or activity)
Background Count
Corrected Count rate
I would like to incorporate the inverse square law, but I am unsure how to do so. I want to measure the intensity or see how it varies. Would that just be [tex]\frac{1}{d^2}[/tex]
Thanks!
Have a column of d^2 times Intensity. Test if its entries are constant for varying d.
thanx
  • · Replies 22 ·
