Diagonalization, eigenvectors, eigenvalues
The discussion revolves around the diagonalization of a given 3x3 matrix, specifically focusing on finding a nonsingular matrix P such that (P^-1)*A*P is diagonal. The matrix in question is | 1 2 3 |, | 0 1 0 |, | 2 1 2 |. Participants are exploring the concepts of eigenvalues and eigenvectors in the context of linear algebra.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the process of finding eigenvalues and eigenvectors, with some attempting row reduction methods. There is questioning of the validity of using row-reduced matrices to determine eigenvalues, with suggestions to expand the determinant for clarity. Some participants express confusion over the eigenvalues derived from their calculations and seek clarification on the steps involved in the determinant expansion.
The discussion is ongoing, with participants providing insights and corrections regarding the eigenvalues. There is a recognition of differing interpretations of the eigenvalues, with some guidance offered on how to approach the determinant calculation. However, no consensus has been reached on the correct eigenvalues or the corresponding eigenvectors.
Participants note that the original matrix is nonsingular and that the eigenvalues should be derived from the characteristic polynomial. There is mention of potential arithmetic mistakes and the importance of understanding the implications of row operations on eigenvalue calculations.
aznkid310
[SOLVED] diagonalization, eigenvectors, eigenvalues
Find a nonsingular matrix P such that (P^-1)*A*P is diagonal
| 1 2 3 |
| 0 1 0 |
| 2 1 2 |
I am at a loss on how to do this. I've tried finding the eigen values but its getting me nowhere
i row reduced to 1 2 3
0 1 0
0 0 -4
and found : (x-1)^2 and (x+4), which gives me eigen values of 1 and -4.
Using A - Ix, when x = -4, the matrix becomes 5 2 3 0
0 5 0 0
2 1 6 0
Using row reduction: 1 2/5 1/5 0
0 5 0 0
2 1 6 0
1 2/5 1/5 0
0 1 0 0
0 1/5 28/5 0
1 2/5 1/5 0
0 1 0 0
0 0 28/5 0
1 0 0 0
0 1 0 0
0 0 1 0
which means X = y = z = 0, but that's wrong
When i use x = 1: 0 2 3 0
0 0 0 0
2 1 1 0
this gives 2y = -3z
2X + y + z = 0 ==> 2X = z/2
If z = 4, then x = 1, y = -6
That's one correct answer, but i can't get the second one, which is suppose to be
X = -3, y = 0, z = 2
| 1 2 3 |
| 0 1 0 |
| 2 1 2 |
Yes, the "diagonal" elements will be the eigenvalues of the matrix and the matrix P has eigenvectors corresponding to those eigenvalues as columns.
0 1 0
0 0 -4
Why in the world would you row-reduce? In general, the eigenvalues of the row-reduced matrix are not the eigenvalues of the original matrix. If it were, there wouldn't be such complicated computer routines for finding eigenvalues!
The eigenvalue equation for your matrix is
[tex]\left|\begin{array}{ccc} 1-\lambda & 2 & 3 \\ 0 & 1-\lambda & 0 \\ 2 & 1 & 2-\lambda \end{array}\right|= 0[/tex].
I recommend expanding on the middle row. That gives
[tex](1- \lambda)\left|\begin{array}{cc} 1- \lambda & 3 \\ 2 & 2-\lambda \end{array}\right|= 0[/tex]
which is easily solved for [itex]\lambda[/itex]= 1, -1, and 4.
0 5 0 0
2 1 6 0
0 5 0 0
2 1 6 0
1 2/5 1/5 0
0 1 0 0
0 1/5 28/5 0
1 2/5 1/5 0
0 1 0 0
0 0 28/5 0
1 0 0 0
0 1 0 0
0 0 1 0
Yes, it is wrong: -4 is not an eigenvalue!
Saying that 4 (not -4) is an eigenvalue gives
[tex]\left[\begin{array}{cccc}-3 & 2 & 3 & 0 \\ 0 & -3 & 0 & 0\\ 2 & 1 & -2 & 0\end{array}\right][/tex]
subtracting 2/3 of the first row from the third row gives
[tex]\left[\begin{array}{cccc}-3 & 2 & 3 & 0 \\ 0 & -3 & 0 & 0\\ 0 & \frac{7}{3} & 0 & 0\end{array}\right][/tex]
and clearly now adding 7/9 of the second row to the third row gives
[tex]\left[\begin{array}{cccc}-3 & 2 & 3 & 0 \\ 0 & -3 & 0 & 0\\ 0 & 0 & 0 & 0\end{array}\right][/tex]
(You don't really need to carry that fourth column along- it will always be 0s). That gives y= 0, z= x so any eigenvector corresponding to eigen value 4 is a multiple of < 1, 0, 1>.
0 0 0 0
2 1 1 0
this gives 2y = -3z
Yes, 1 is an eigenvalue, but not a double eigenvalue. -1 is the third eigenvalue.
Could you explain what you did here? What do you mean my expanding the middle row?
You can use the zeros in a matrix to make your work easier (and less likely to introduce arithmetic mistakes - a worthy skill to develop :smile:).
Remember that if you switch a row/column in the determinant, you change the sign of determinant? Well, imagine switching row1 with row2, then col2 with col1 (for a net sign change of +1).
Now, if you calculate your determinant using expansion of minors, all the zeros help you out, so that you are taking (1-λ) times the determinant of the remaining, smaller matrix, as HallsofIvy showed.
If you calculate your determinant by drawing the diagonal lines & multiplying, only the lines that go through (1-λ) will be non-zero, and you'll get the same result.
This thread is 3 years old...
