How Do You Calculate a(t+dt) Using the Velocity Verlet Algorithm?
  • Thread starter Thread starter shad0w2000
    Algorithm
The discussion focuses on calculating a(t+dt) using the Velocity Verlet algorithm for simulating the dynamics of a particle. The Langevin equation is employed, where acceleration a(t) is defined as a combination of velocity, external forces, and fluctuating forces. The user expresses uncertainty about using v(t) in the calculation of a(t+dt) and seeks clarification on whether this approach is valid. The response emphasizes the semi-implicit nature of the Verlet integrator, suggesting that numerical solutions are necessary at each step and questioning the necessity of using the Verlet method over alternatives like the Runge-Kutta family.
  • Understanding of the Langevin equation and its components
  • Familiarity with the Velocity Verlet algorithm
  • Knowledge of numerical methods for solving differential equations
  • Basic concepts of harmonic forces and their mathematical representation
  • Study the implementation of the Velocity Verlet algorithm in Python or C++
  • Learn about the Runge-Kutta methods for solving ordinary differential equations
  • Explore the concept of semi-implicit integrators in numerical simulations
  • Investigate the effects of fluctuating forces in Langevin dynamics simulations
Researchers and students in computational physics, particularly those working on molecular dynamics simulations or anyone interested in numerical methods for solving differential equations.
shad0w2000
I am going to use the velocity verlet algorithm to simulate the position, velocity and acceleration at time t of some particle.
We got the Langevin equation: a(t) = -v(t)/tau - U'(x) / m + F_f(t) / m
Where tau is the mass divided by the friction coefficient, U'(x(t)) the external force and F_f(t) the fluctuating force. Let's say the external force is harmonic, ½kx(t)^2, so U'(x(t)) / m = kx(t)/m.
I have so far typed in x(t+dt), v(t+dt/2) and I need to find what a(t+dt) is. It's easier if you go see http://en.wikipedia.org/wiki/Verlet_integration" for the equations i refer to :)
As for a(t+dt) I am in doubt how I should find this, what I tried so far is:
a(t+dt) = -1/m * dV(x(t+dt))/dx
= -v(t) / tau - k*x(t+dt) / m + F_f(t)
(Where I take the value of the fluctuating force randomly from a normaldistribution)
My doubt is about the use of v(t), can I use v(t) in the above equation? I don't see how many other options I have since we need a(t+dt) to be able to calculate v(t+dt), or have I missed something?
I hope someone can help me a bit, if you need more info or anything is unclear, please tell me here.
No one able to help? :)
The verlet integrator is semi-implicit, which means exactly what you've noticed: you need [tex]v(t+dt)[/tex] to calculate [tex]a(t+dt)[/tex]. In general this means that you need to solve an equation at each step (numerically). Do you have to use Verlet? The usual Runge-Kutta family is pretty good, or even just plain ol' midpoint rule?
