Evaluating a QB's Claim: Speed of Throw Required
  • Thread starter Thread starter gmunoz18
    Speed
The problem involves evaluating a quarterback's claim regarding the speed required to throw a football a horizontal distance of 169.1 m at an angle of 30° above the horizontal, assuming no air resistance and that the ball is launched and caught at the same vertical level.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods for solving the problem, including breaking the motion into horizontal and vertical components and using kinematic equations. Some question the assumptions made regarding time and the use of specific formulas for projectile motion.
There are multiple approaches being explored, with some participants suggesting alternative methods that may simplify the problem. Guidance has been offered regarding the separation of motion into components and the use of specific equations, though there is no explicit consensus on the best method to use.
Some participants express uncertainty about the equations and methods being discussed, indicating a potential gap in familiarity with the relevant physics concepts. There is also mention of previous learning experiences related to projectile motion equations.
gmunoz18
On this problem i have gotten stuck and i am not really sure why.
A quarterback claims that he can throw the football a horizontal distance of 169.1 m (185 yd). Furthermore, he claims that he can do this by launching the ball at the relatively low angle of 30° above the horizontal. To evaluate his claim, determine the speed with which this quarterback must throw the ball. Assume that the ball is launched and caught at the same vertical level and that air resistance can be ignored.
kinematics equations
First I cut the trajectory in half to find the footballs maximum height
than on the y coordinate is at its vertex its velocity at that point is 0 so i was able to put that in as well
So my list came out as is
X coordinate Y coordinate
X=84.55 Y=48.814
Xi=0 Yi=0
a=0 a=-9.8 m/s/s
Vi=? Vi=?
V=? V=0
than in order to get more information i solved for the ball to hit the ground from its highest altitude i.e. 48.814 meters.
dist = 1/2 g t^2 (g=9.8 m/s/s) so i used this equation and came up with 3.1562 seconds
Now I was able to solve for Vi for Y coordinate which i got 30.93m/s
after this i just used the sin(30)=30.93/x and i got 61.8628m/s
Was there an easier way to do this problem am i missing something very simple? but this answer is not matching up and can't seem to get it
thanks i advance
sorry about the double post!
This way may be a little easier, and I got an answer that works.
Just use the kinematic equation:
[tex]\Delta s = v_i t + \frac{1}{2} a t^2[/tex]
for each direction x and y. For each velocity, separate [tex]v_i[/tex] into components. Then you have two equations with two unknowns, so you can then solve for each unknown.
would i use the seconds that i solved for t?
No. You're basically starting over with t as an unknown.
I did the problem myself this way. It's not too bad and really shouldn't take too long, I don't think as long as finding the height then the time the way you did.
To get you started a bit, write down the variables you already know, x, y, a.
Your unknowns are v and t. But you do know how to split v into [tex]v_1x[/tex] and [tex]v_1y[/tex]. So, then you should be able to solve for both t and v.
ohh wow that is a lot easier thanks for the help
Its a good practice to go the basic way--splitting the motion into horizontal and vertical, but this question can also be solved by using this formula for horizontal range. Isn't it faster to put in the values and get the result ?
[tex]R=\frac{v^2 sin2\theta}{g}[/tex]
I have not encountered this equation yet but when i used it i did not get the correct answer. this is as R as the entire range correct?
I am pretty much confident that this equation is correct. and yes, R is the complete horizontal range, which, according to your question is 169.1 m
I got v=43.74 m/s.
maybe I'm wrong..:redface:
I got v=43.74 m/s.
No, that's the answer I got doing it the other way, but I'm not familiar with that equation either.
Maybe you'll encounter these equations later. They are all over in books on projectile motion.
My teacher derived these equation for us, by splitting the motion into horizontal and vertical components.
Its like this :
Time of flight=[tex]\frac{2vsin\theta}{g}[/tex]
Range= [tex]\frac{v^2 sin2\theta}{g}[/tex]
Max height=[tex]\frac{v^2 sin\theta}{2g}[/tex]
I got v=43.74 m/s.
thats what i got i did it with only half the distance at first ha but when i did it for the full 169.1 it was perfect!
Thanks a lot googlespider and chococat you helped a lot!
What physics are you in google_spider? general, calc based?
  • · Replies 38 ·
