Capacitance of a parallel plate capacitor with two dielectrics
The capacitance of a parallel plate capacitor filled with two dielectrics of equal thickness and dielectric constants k1 and k2 is calculated using the series capacitor formula. The individual capacitances are derived as C1 = (2k1ε0A)/d and C2 = (2k2ε0A)/d. The total capacitance is then given by Ct = (2ε0Ak1k2)/(d(k1 + k2)). This method effectively treats the capacitor as two capacitors in series, confirming the validity of the approach for this configuration.
  • Understanding of parallel plate capacitors
  • Familiarity with dielectric materials and their properties
  • Knowledge of series and parallel capacitor combinations
  • Basic grasp of electromagnetic theory
  • Study the effects of varying dielectric constants on capacitance
  • Learn about the energy stored in capacitors with dielectrics
  • Explore the applications of capacitors in electronic circuits
  • Investigate the impact of capacitor geometry on performance
Students of electrical engineering, physics enthusiasts, and professionals working with capacitors in electronic design and applications.
iamaelephant
[SOLVED] Capacitor with 2 dielectrics
A parallel plate capacitor of plate area A and spacing d is filled with two parallel slabs of dielectric of equal thickness with dielectric constants k1 and k2, respectively. What is the capacitance?
You tell me.
I wasn't sure if I could do something simple like take an average of the dielectric constants (although I suspect not). Instead I split the capacitor into two series capacitors and added them in the usual way. Is this allowed? Off the top of my head it seems to be okay, but I'm probably wrong.
In any case, here is my working. This electromagnetic stuff is definitely my weak hand so advice on these types of problems would be great.
Splitting the capacitor into two series capacitors, we can get their capacitances using the equation
[tex] C_1 = \frac{k_1 \epsilon_0 A}{\frac{d}{2}}<br /> = \frac{2k_1 \epsilon_0 A}{d}[/tex]
[tex] C_2 = \frac{k_2 \epsilon_0 A}{\frac{d}{2}}<br /> = \frac{2k_2 \epsilon_0 A}{d}[/tex]
[tex]\frac{1}{C_t} = \frac{1}{C_1} + \frac{1}{C_2} = \frac{d}{2 k_1 \epsilon_0 A} + \frac{d}{2 k_2 \epsilon_0 A}<br /> = \frac{2 d \epsilon_0 A (k_1 + k_2)}{(2 k_1 \epsilon_0 A)(2 k_2 \epsilon_0 A)}[/tex]
[tex]C_t = \frac{2 \epsilon_0 A k_1 k_2}{d(k_1 + k_2}[/tex]
This is the correct way to go about the problem. The capacitor filled with two dielectrics can be considered to be two capacitors in series with different dielectrics.
Excellent, thanks so much. I'm stoked I got this one right, a rare hit for me in EM :P
  • · Replies 21 ·
