What is the Magnetic Field at the Center of a Wire with a Loop?
  • Thread starter Thread starter feedmeister
    Loop Wire
The magnetic field at the center of a circular loop of wire carrying a current can be calculated using the formula \( B = \frac{\mu_{o}I}{2r} \). In this discussion, a current of 4.8 amperes and a loop radius of 7.7 cm were provided. The user initially calculated the magnetic field as 0.0000392 T, which was incorrect. The correct approach requires adding the magnetic field contribution from both the loop and the straight wire segment.
  • Understanding of Ampère's Law
  • Familiarity with magnetic field calculations
  • Knowledge of the permeability of free space (\( \mu_{o} \))
  • Basic algebra for manipulating equations
  • Review the derivation of Ampère's Law
  • Learn how to calculate the magnetic field from straight current-carrying wires
  • Study the superposition principle in magnetic fields
  • Explore applications of magnetic fields in electrical engineering
Students studying electromagnetism, physics educators, and electrical engineers seeking to understand magnetic field calculations in current-carrying conductors.
feedmeister
A very long wire carrying a conventional current of 4.8 amperes is straight except for a circular loop of radius 7.7 cm. Calculate the approximate magnitude of the magnetic field at the center of the loop.
I know that I=4.8A and r = .077m
u_o = 4*pi*(10^-7)
[tex]\mu_{o}I/2r[/tex]
I have everything and have been getting .0000392 T for the answer, but it's wrong.
Please help! (ASAP Appreciated...) What am I doing wrong??
You calculated the field due to the loop current correctly. I think you need to add to that the contribution to the magnetic field that comes from the straight part of the wire.
Yep, thanks a lot.
