KVA's and electrical connections to a residential development
  • Thread starter Thread starter teslaspal
    Electrical
The local electricity company has indicated that the existing infrastructure cannot support the electrical load for a residential development, requiring the installation of a new transformer. The current three-phase transformer can only provide 200kVA, while the development needs 600kVA. There is confusion regarding the transformer capacity, as it is believed that the KVA rating does not multiply with the number of phases. The discussion highlights the misunderstanding of how transformer capacity works in relation to load requirements. Clarification on this issue is essential for moving forward with the electrical connection.
teslaspal
Hi there, new to the forum and had a question I was hoping that you folks could help out with.
I have recently made application to our local electricity company for electrical connections to a residential development.
I have given them a breakdown of all the loads which are single phase domestic.
They have come back and mentioned that they don't think the infrastructure can support the load and they need us to pay for a new transformer.
They only have 200kva available from the existing three phase transformer and I need 600kva.
Now, I am slightly confused with this, as surely the 200kva (three phase) will support my 3 x 200kva requirements?
The transformer KVA does not get multiplied by the number of wires.
That is a total.
So if you draw 1 line x 600, 2 lines x 300 or 3 lines x 200, it still adds up to 600kva that the transformer sees.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
