Thread Closed
Molecular diffusion question; fick's first law
Share Thread
Mar1-08, 12:33 PM   #1
Calculate the flux of oxygen across a square centimeter membrane [2[tex]\mu[/tex], or 2x10 [tex]^{-6}[/tex]m thick if the concentration on the right hand side of the membrane is 4mL/L and on the left side is 2mL/L.
2. Relevant equations
fick's first law of diffusion
Flux = dC/dx = D[C2-C1] where D is the molecular diffusion constant
molecular diffusion constant for oxygen = 3x10^-5
3. The attempt at a solution
Using the first eq, I took the difference in the concentrations, and divided it by the thickness of the membrane. [4mL/L-2mL/L]/ 2[tex]\mu[/tex], which resulted in a flux of 1x10[tex]^{6}[/tex]... however, the equation did not take into account the molecular diffusion constant of oxygen, which was provided in the problem. So then I tried the second equation. 3x10[tex]^{-5}[/tex]x[4mL/L - 2mL/L]= 6x10[tex]^{-5}[/tex]. however, the second equation does not take into account the thickness of the membrane (dx). Im totally lost and have no idea what to do. please help thanks!
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Mar1-08, 07:20 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
You're almost there, but your flux equation looks a little off. Make sure to use the right equation and work through the problem again using the correct units, and things should work out fine.
Mar2-08, 11:23 AM   #3
after doing a little research, I come to realize that the diffusion equation (Fick's first law) is actually
Flux = -D[([tex]\Delta[/tex]C)/([tex]\Delta[/tex]x]
where D is the diffusion coefficient;
where C is the concentration
where [tex]\Delta[/tex]x is the thickness of the membrane
therefore, -3x10^-5 [(2mL/L)/(2x10^-6m)]= -30 [mol]/[m^2 sec]
Thread Closed
Similar discussions for: Molecular diffusion question; fick's first law
Thread Forum Replies
Fick's Law Materials & Chemical Engineering 6
Diffusion equation and neutron diffusion theory Nuclear Engineering 15
Fick's 1st/2nd law Engineering, Comp Sci, & Technology Homework 5
A question about conservative diffusion. General Physics 6
