Determine acceleration when velocity is v=x^3-4x^2+7x
The problem involves determining the acceleration of a particle moving along the x-axis, given its velocity as a function of position, v = x³ - 4x² + 7x. The specific point of interest is when x = 5 m.
  • Participants discuss the differentiation of the velocity function to find acceleration, with some questioning the need for the chain rule. There is confusion regarding the notation used for acceleration.
The discussion includes attempts to clarify the relationship between velocity and acceleration, with some participants providing insights on differentiation. There is an ongoing exploration of the correct approach to differentiate the velocity function.
Participants express uncertainty about the application of differentiation rules and the correct interpretation of variables involved in the problem.
kring_c14
The velocity of a particle moving along the x-axis is given by v=[tex]x^{3}[/tex]-4[tex]x^{2}[/tex]+7x whwere x is in meters and v in m/s. determine the acceleration when x=5m...
the thing i know is that i just can't differentiate v to get y, since it is a function of x..
i don't know if chain rule would work..and i don't know how to do it..
Thanks in advance!
Where are you getting a "y"?
Just find [tex]\frac{dv}{dt}|_{x=5m}[/tex]
[/tex]
sorry..i typed the wrong letter...it should be "a"..
may you pls explain further.. should i differentiate the equation?
Well acceleration is defined as a rate of change of velocity: [tex]\frac{d(v)}{dt}[/tex].
Since acceleration is just a change in velocity, you can differentiate a velocity function to get an acceleration function.
As to differentiating the function, I don't believe you'd need to use the chain rule at all, because v(t) is not in a form of f(g(x)) where f(x) and g(x) are two functions, it's cases like v(t)=f(g(x)) where the chain rule would be applied in differential calculus.
a=dv/dt=3*x^2 - 8*x+7
a(x=5m)=42 m/s^2
  • · Replies 20 ·
