Force on a Current Carrying Conductor
The discussion centers on determining the conditions under which a magnetic force acts on a current-carrying conductor, specifically identifying scenarios that result in a force directed due north. The correct answers include the situation where the current flows straight up while the magnetic field points due east, as well as the scenario where the current flows due west and slightly up with the magnetic field pointing due east. The right-hand rule is applied to ascertain the direction of the force based on the orientation of the current and magnetic field.
  • Understanding of the right-hand rule and left-hand rule in electromagnetism
  • Basic knowledge of magnetic fields and forces on conductors
  • Familiarity with vector analysis in physics
  • Concept of current flow in electrical circuits
  • Study the right-hand rule in detail to predict force directions in magnetic fields
  • Explore the principles of electromagnetism, focusing on Lorentz force law
  • Investigate applications of magnetic forces in electrical engineering
  • Learn about the effects of varying current and magnetic field orientations on force outcomes
Students studying physics, particularly those focusing on electromagnetism, as well as educators and professionals seeking to deepen their understanding of magnetic forces on conductors.
mit_hacker
Which of the following situations would result in a magnetic force on the wire that points due north?
Check all that apply.
Current in the wire flows straight down; the magnetic field points due west.
Current in the wire flows straight up; the magnetic field points due east.
Current in the wire flows due east; the magnetic field points straight down.
Current in the wire flows due west and slightly up; the magnetic field points due east.
Current in the wire flows due west and slightly down; the magnetic field points straight down.
Right hand rule of left hand rule
I know that the third one is correct but it says that the answer is wrong which means there is atleast one other correct answer but I have NO CLUE which one that is. Please help.
A. When the current is up and the magnetic field is East, the force is North.
B. When both current and field in A are reversed, the force is North.
If the current is mostly West and slightly up you have situation A but a weaker force to the North.
  • · Replies 40 ·
  • · Replies 20 ·
