Doppler wavelength shift equation
The discussion revolves around the Doppler wavelength shift equation, specifically in the context of light emitted from the sun. Participants explore different equations applicable to various scenarios involving moving emitters and receivers.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant asks for the Doppler wavelength shift equation.
  • Another participant mentions there are multiple equations: one for a moving emitter, one for a moving receiver, and a combined equation.
  • A different participant seeks to understand the wavelength shift for light emitted from the sun and questions if a different equation applies specifically for light.
  • One participant provides the relativistic Doppler shift equation and suggests that for the speed of Earth to Sun, the classical formula might suffice.
Participants express varying views on the applicability of different equations for the Doppler effect, indicating that multiple competing models exist without a consensus on which is most appropriate for the scenario discussed.
There is uncertainty regarding the specific conditions under which each equation is applicable, and participants do not clarify the assumptions or limitations of the equations mentioned.
bse
Can anyone tell me what the doppler wavelength shift equation is?
thanks
I'm trying to find the wavelength shift for light with a certain wavelength that is emitted from the sun. Is there a different kind of equation for light wavelength shifts?
There's the relativistic Doppler shift, [tex]\lambda= \lambda _0 \sqrt{ \frac{1+v}{1-v}}[/tex]
But if you're only making the correction of the speed Earth to Sun, the classical formula is enough, I think
  • · Replies 19 ·
