Thread Closed
Melting metal
Share Thread Thread Tools
Mar3-08, 03:03 PM   #1
Recognitions:
Gold Membership Gold Member
Melting metal
I have a bet that no chemical can cut through hardened steel like in the movies, will i loose?
PhysOrg.com
PhysOrg
chemistry news on PhysOrg.com
>> New method for producing clean hydrogen
>> Making ice-cream more nutritious with meat left-overs
>> Non-wetting fabric drains sweat
Mar3-08, 03:41 PM   #2
There are some wicked reagents out there that can eat steel up pretty quick. Could you better define how you mean by 'in the movies'?
Not to mention stuff like a Thermite reaction that can quickly melt through steel just using gravity and a glob of molten hot iron and aluminum.
Mar3-08, 03:55 PM   #3
Recognitions:
Quote by LtStorm View Post
The secret agent has a phial of chemical , that will cut through the lock in seconds.
Mar3-08, 04:00 PM   #4
Melting metal
I don't know about exact rates, but a vial of freshly prepared Royal Water could probably do it pretty quickly. Of course, this is ignoring the problems of applying the reagent to the lock, and is assuming something like a padlock where it could be poured directly onto the small locking arm to eat up/weaken that enough that it can be snapped off by hand.
Injecting it with a pipette into any other kind of key lock would certainly wreck the mechanism, but may or may not make it easier to open....
Mar6-08, 08:35 PM   #5
Royal water is good if you can heat it; at cold is better to have more HNO3 than HCl and add also HF; with this mix you can dissolve easily (but not as quickly as in movies) even stainless steel.
Don't breath the acid vapours.
Thread Closed
Thread Tools
Similar Threads for: Melting metal
Thread Forum Replies
Im melting General Discussion 18
How to change the melting point of a metal? Materials & Chemical Engineering 1
bending property solid metal pipe vs hollow metal pipe General Engineering 4
melting ice Introductory Physics Homework 3
Melting of ice Introductory Physics Homework 7
