Rotational Inertia, Torque & Angular Acceleration of 4-Particle Rigid Body
  • Thread starter Thread starter Clutch306
    Hard
The discussion focuses on the calculations of rotational inertia, net torque, and angular acceleration for a rigid body consisting of four particles, each with a mass of 0.200 kg, arranged at the vertices of a square with a side length of 0.500 m. The rotational inertia (I) about axis A is determined to be 0.100 kg·m² using the formula I = Σmr². The net torque (Tnet) about axis A, when the rod AB is horizontal, is calculated to be 3.92 Nm using Tnet = ΣrFsinθ. Finally, the angular acceleration (a) is found to be 39.2 rad/s² using the relationship a = Tnet/I.
  • Understanding of rotational dynamics and inertia
  • Familiarity with torque calculations
  • Knowledge of angular acceleration concepts
  • Proficiency in using formulas related to rotational motion
  • Study the derivation of the rotational inertia formula I = Σmr²
  • Learn about the effects of different axis of rotation on torque calculations
  • Explore the relationship between torque and angular acceleration in rigid body dynamics
  • Investigate real-world applications of rotational motion principles in engineering
Physics students, mechanical engineers, and anyone interested in the principles of rotational dynamics and their applications in real-world scenarios.
Clutch306
Four particles, each of mass 0.200kg, are placed at the vertices of a square with sides of length 0.500m. The particles are connected by rods of negligible masses. This rigid body can rotate in a vertical plane about a horizontal axis that passes through one of the particles (A for example, as shown in figure attached.)
(a) What is the rotational inertia I of the body about axis A?
(b) What is the net torque Tnet about axis A (due to the gravitational forces), when the rod AB is horizontal?
(c) What is the angular acceleration a of the body at the instant rod AB is horizontal?
Others have said it in your other threads, but you must show what you've tried, Clutch.
https://www.physicsforums.com/showthread.php?t=28
(a) The rotational inertia I of the body about axis A can be calculated using the formula I = Σmr², where m is the mass of each particle and r is the distance from the axis of rotation. In this case, the particles have the same mass (0.200kg) and the distance from the axis of rotation is 0.250m (half of the side length of the square). Therefore, the rotational inertia I = 4(0.200kg)(0.250m)² = 0.100kgm².
(b) The net torque Tnet about axis A can be calculated using the formula Tnet = ΣrFsinθ, where r is the distance from the axis of rotation, F is the force acting on the particle, and θ is the angle between the force and the line connecting the particle to the axis of rotation. In this case, the only force acting on the particles is the gravitational force, which is directed towards the center of the earth. Since the particles are arranged in a square, the angle between the force and the line connecting the particle to the axis of rotation is 45 degrees. The distance from the axis of rotation is 0.250m (half of the side length of the square). Therefore, Tnet = 4(0.250m)(0.200kg)(9.8m/s²)sin45° = 3.92Nm.
(c) The angular acceleration a of the body can be calculated using the formula a = Tnet/I, where Tnet is the net torque and I is the rotational inertia. Substituting the values calculated in parts (a) and (b), we get a = (3.92Nm)/(0.100kgm²) = 39.2 rad/s². This means that the body will experience an angular acceleration of 39.2 rad/s² in the direction of the net torque when the rod AB is horizontal.
18K
  • · Replies 30 ·
  • · Replies 33 ·
