Find the Maclaurin series for f(x) = (x^2)(e^x)
The discussion revolves around finding the Maclaurin series for the function f(x) = (x^2)(e^x). Participants explore the process of obtaining the series by multiplying the known Maclaurin series for e^x with x^2, leading to questions about the validity of this approach and the nature of Maclaurin series for polynomials.
  • The original poster questions the reasoning behind multiplying the Maclaurin series for e^x by x^2, suggesting a need for clarity on why this is permissible. Other participants clarify that any polynomial, including x^2, is its own Maclaurin series, which leads to further inquiries about the implications of this fact.
Participants are actively engaging with the concepts of Maclaurin and Taylor series, with some providing clarifications and examples. There is a recognition that understanding the relationship between functions and their series expansions is crucial, although some participants express confusion about the broader implications of these series.
Some participants mention their struggles with understanding Taylor and Maclaurin series, indicating a potential gap in foundational knowledge that may affect their ability to engage with the problem effectively.
ggcheck
the book suggests obtaining the Maclaurin series of f(x) by multiplying the known Maclaurin series for e^x by x^2:
(x^2)(e^x) = (x^2)(1 + x + (x^2)/2! + (x^3)/3! + (x^4)/4! + ...)
= x^2 + x^3 + (x^4)/2! + (x^5)/3! + (x^6)/4! + ... = sum(from n=2, infin) (x^n)/(n-2)!
my question is:
why can we multiply the Maclaurin series for e^x by x^2? wouldn't we have to multiply one Maclaurin series by another, i.e. the Maclaurin series of e^x by the Maclaurin series for x^2?
I hope this questions makes sense. Thanks
Looks like you missed something.
Edit: you're post was initially blank.
pardon?
The Maclaurin series for x^2 IS x^2.
ugh. I guess I need to study Taylor/Maclaurin series more because I don't understand them very well.
thanks for the help; it would have been nice if my book told me that, though
Any polynomial in x would be it's own Maclaurin series, just so you know.
I had no idea... and I read the chapter in my textbook on Taylor/Maclaurin series...
It's pretty clearcut. Just follow the recipe for building a Maclaurin series for a polynomial of the general form, and lo and behold the answer will be the original polynomial.
I suck a building them
It only requires finding derivatives and evaluating them at x = 0. When the original function is a polynomial I am hopeful that you find taking a derivative to be a piece of cake!
but don't you need to notice a pattern to find the equation for the general derivative?
i.e. f^(k)(x) = ?
Here's an example:
Take the Maclaurin series of f(x) = Ax^3 + Bx^2 + Cx + D (degree 3 polynomial)
f(0) = D
f ' (x) = 3*Ax^2 + 2*Bx + C so f ' (0) = C
f '' (x) = 3*2*Ax + 2*1*B so f ''(0) = 2!B
f ''' (x) = 3*2*1*A so f ''' (0) = 3!A
f ''''(x) = 0 (and all higher derivatives as well are 0)
It's the last bit that makes it easy, the fact that all derivatives that are of order greater than the polynomial degree vanish.
Now if you plug those into the Taylor coefficients out will pop your original polynomial.
Why bother finding derivatives? Use facts you know about power series. For example, two convergent power series are equal if and only if they have the same coefficients.
Mathdope said:
Here's an example:
f(0) = D
wow, thank you very much for explaining that to me... I spent at least an hour reading my book and a few websites and I didn't get it until just now (maybe I'm too tired)
would the solution process differ greatly if we were trying to find the Taylor series and not the Maclaurin series (not at a = 0)?
I'm not following you.
I don't think I can effectively answer this question unless you could explain why would you think that you can't.
e^x and x^2 are two functions. Multiplication is defined for any two functions. The expression "e^x" and Maclaurin series for e^x are just two different ways of writing the same function.
The Maclaurin series for x^2 is a power series, right?
"x^2" is a power series right?
The expression "x^2" and the Maclaurin series for x^2 both denote the same function, right?
So...
that part of the question has already been addressed... I did not know that the Maclaurin series of x^2 was x^2
This tidbit of knowledge is entirely irrelevant to the problem. You didn't have to know that "x^2" was the Maclaurin series for x^2.
The process wouldn't differ, i.e. if you wanted to take the Taylor Series of a polynomial about x = a you would evaluate all your derivatives at x = a instead of at x = 0. As an example, if I took the Taylor series of the general 3rd degree polynomial at x = 1 I'd have
f (1) = A + B + C + D
f ' (1) = 3A + 2B + C
f '' (1) = 6A + 2B
f '''(1) = 6A
f ''''(1) = 0
...and then I would plug those in as the Taylor coefficients. The only other bit you would need to include is that now your Taylor series is in powers of (x-1) instead of powers of x.
ugh how did I get here? I no good with taylor series
f (1) = D
f '' (1) = 6A + 2B
f '''(1) = 6A
f ''''(1) = 0
Of course, you could just rewrite x as (x-1) + 1, and expand the polynomial. Taylor's theorem is probably easier, though... unless you're really good with Pascal's triangle.
time for class--I will review this page later
thanks!
The main point is just that every polynomial is its own Taylor Series, irrespecitve of about what point it is taken. It will always come out to be itself.
Sure. If you expand around, say x=1, then the Taylor expansion of x^2 is 1+2(x-1)+(x - 1)^2. And e^x becomes e+e*(x-1)+e*(x-1)^2/2+... Now you have a complicated looking problem. But if you multiply out the expansion of x^2, it's still just x^2. It pays to expand around a point where the expansions become easy.
  • · Replies 48 ·
  • · Replies 38 ·
