Prove Intersection of A and B is Empty Set if B Subset of X/A
  • Thread starter Thread starter chocolatelover
    Intersection Proof
The discussion revolves around proving that the intersection of sets A and B is empty if and only if B is a subset of the complement of A in a universal set X. The subject area pertains to set theory and logical proofs.
  • Participants explore the idea of proving the statement by contrapositive and by contradiction. There are discussions about the implications of B being empty and the relationship between the sets involved.
Some participants have provided guidance on how to approach the proof, suggesting different methods such as proving both directions of the "if and only if" statement. There is an ongoing exploration of logical reasoning and set relationships, with no explicit consensus reached.
Participants are navigating the requirements of the proof, including the need to demonstrate both directions of the statement and the implications of set membership. There is an acknowledgment of the complexity involved in the logical structure of the proof.
chocolatelover
Prove A intersects B=empty set if and only if B is a subset of (X/A)
Would I prove the contrapositive in this case?
If B is not a subset of (X/A), then the intersection of A at B is not the empty set
Could someone please show me what to do?
Thank you very much
"if and only if" means that you must prove the statement both ways. Proving by contradiction seems the easiest way for each. The approach you suggest will only get you half the proof.
Thank you very much
Could you show me where to go from there?
Thank you
Well since you wanted to use the contrapositive for A intersects B = empty -> B is a subset of X\A I'll explain that way. Let [itex]B=\{b_1,b_2,...\}[/itex]. If B is empty what we want is vacuously true since the empty set is a subset of every set (and thus B can never not be a subset of [itex]X \setminus A[/itex]). If [itex]B\not\subset X\setminus A[/itex] then at least one [itex]b_i \in B[/itex] is [itex]\in X\setminus (X \setminus A) = A[/itex] which implies A and B have these elements in common.
You can prove the other way in a similar fashion. My personal suggestion is contradiction for the other way.
On this note, you have another question that's pretty similar. Your questions really boil down to choosing elements of certain sets and then showing by logic that they must/must not exist in other sets. Try to proceed like this in your other question also.
Thank you very much
Regards
