Direction of the Magnetic Field due to a Wire
The discussion revolves around determining the direction of the magnetic field at specific points (C, D, E) due to current-carrying wires, utilizing the Right Hand Rule for a Straight Wire.
  • Exploratory, Assumption checking
  • Participants discuss the individual contributions of different current magnitudes at point D and how they affect the magnetic field direction. There is an emphasis on the application of the Right Hand Rule and the reasoning behind the magnetic field directions at points C and E.
Some participants have provided insights into the reasoning for the magnetic field directions at points C and E, while others are exploring the implications of differing current magnitudes on point D. There is acknowledgment of the need for further clarification on the reasoning behind the magnetic field at point D.
Participants are navigating assumptions regarding the current values and their effects on the magnetic field, particularly at point D, where the relationship between I_1 and I_2 is under scrutiny.
cse63146
[SOLVED] Direction of the Magnetic Field due to a Wire
Find the magnetic field at point C, D, E.
The choices are for all 3 are
i) Out of the page
ii) Into the page
iii) Not into the page or not out of the page, and not = 0
iv) 0
The Right Hand Rule for a Straight Wire
I believe the answer for:
C - Out of the page
D - Not into the page or not out of the page, and not = 0
E - Into the page
Any help would be appreciated.
Think about the individual contributions of I and 2I for point D, and then add up. C and E are correct, even though you didn't give any reason.
I used the Right Hand Rule for a Straight Wire, I just didnt know how to describe what I did.
Thank you for the suggestion for D.
So since I_1 doesn't equal I_2, D can't be 0.
Since I_2 > I_1, it would have more effect on it, using the right hand rule for a straight wire, D would be coming out of the page
Right.
Thank You for your help.
