Projectile Motion Sail Boat Problem: Finding Speed and Direction After a Gust
The problem involves a sailboat initially traveling east at a speed of 5 m/s, which experiences an acceleration of 0.8 m/s² at an angle of 40 degrees north of east due to a gust of wind. The questions posed are about determining the boat's speed and direction after 6 seconds once the gust subsides.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the initial velocity and the impact of the gust on the boat's speed and direction. There are questions about whether the initial velocity should be considered as zero and how to properly apply the equations of motion, including the use of components and the Pythagorean theorem.
Some participants have provided feedback on the initial assumptions regarding the initial velocity and have suggested reconsidering the approach to calculating the resultant speed and direction. There is an ongoing exploration of how to correctly apply the relevant equations and concepts.
Participants are navigating the complexities of vector components and the effects of acceleration at an angle, indicating a need for clarity on how to combine these elements in the context of the problem.
Kster
A sailboat is traveling east at 5m/s. A sudden gust of wind gives the boat an acceleration 0.8m/s^2 (40 degrees north of east).
1. What is the boat's speed 6 seconds later when the gust subsides?
2. What is the boat's direction 6 seconds later when the gust subsides?
v = v0 + at
A^2 + B^2 = C^2
I'm so stuck, please tell me what I did wrong.
Hi Kster!
Your v_0 shouldn't be 0 (it would only be 0 if the wind was North or South).
Try again! :smile:
Thank you for replying, ok so I fixed it:
The Opposite Side:
Vo + at = V
(5m/s?) + (0.8 m/s^2 * 6 sec) = 9.8 m/s
My question is, is 9.8m/s my answer to the boat's speed 6 seconds later? or Do I have to use the Pythagorean Theorem to figure out the Hypoteneuse side and that is my answer?
No.
You must do everything in the same direction.
The acceleration is at 40º, so you must use the component of initial velocity along that direction too (using cos).
You then use Pythagoras to combine that result with the perpendicular component of initial velocity (which will be unaffected). :smile:
