How to Find the Laplace Transform of an Unknown Solution Function?
  • Context: Graduate
  • Thread starter Thread starter Lucy77
    Laplace
The discussion focuses on finding the Laplace Transform of the unknown solution function for the initial value problem defined by the differential equation y'' + 4y' - 5y = te^t, with initial conditions y(0)=1 and y'(0)=0. The key takeaway is that Laplace transforms are linear, allowing for the individual transformation of each term in the equation. The formula for the Laplace transform of a derivative is provided, specifically L{y^{(n)}} = s^nY(s) - s^{n-1}y^{(n-1)}(0) - s^{n-2}y^{(n-2)}(0) - ... - y(0), which is crucial for solving the problem.
  • Understanding of Laplace Transforms
  • Familiarity with differential equations
  • Knowledge of initial value problems
  • Basic proficiency in using LaTeX for mathematical expressions
  • Study the properties of Laplace Transforms, particularly linearity
  • Learn how to apply Laplace Transforms to solve initial value problems
  • Explore the use of LaTeX for formatting mathematical equations
  • Investigate the inverse Laplace Transform to find the original function
Mathematics students, engineers, and anyone involved in solving differential equations or applying Laplace Transforms in their work.
Lucy77
This one has me stumped
Find the Laplace Transform of the unknown solution function for the following initial value problem:
y'' + 4y' - 5y = te^t, y(0)=1, y'(0)= 0
(Do Not actually find the function, only its transform. Then, without carrying out the steps, indiacate briefly how you would proceed to find the unknown solution function.)
Thanks
As with your other question, Laplace transforms are linear thus you can do each elemnt individually. What have you done thus far?
Also, [itex]L \{ y^{(n)} \}[/itex]
where n is the derivative is
[tex]s^nY(s)-s^{n-1}y^{(n-1)}(0)-s^{n-2}y^{(n-2)}(0)-...-y(0)[/tex]
PS. click on the equation to see how to use LaTex extensions. A little popup box should appear with a "click to read LaTex guide" at the bottom.
Good luck.
  • · Replies 17 ·
  • · Replies 22 ·
10K
10K
10K
