Power particle-like object problem
  • Thread starter Thread starter critch
    Power
The discussion focuses on calculating the instantaneous power of a particle-like object subjected to a force vector F = (5.0 N) i - (1.0 N) j + (10.0 N) k and a velocity vector v = - (2.0 m/s) i + (4.0 m/s) k. The correct method involves taking the dot product of the force and velocity vectors to determine the power, which is defined as P = F · v. Additionally, when the velocity has only a j component and the instantaneous power is -12 W, the velocity can be found by equating the dot product of the force and the velocity to the given power.
  • Understanding of vector operations, specifically dot products
  • Familiarity with Newton's laws of motion
  • Basic knowledge of power calculations in physics
  • Proficiency in manipulating unit vectors
  • Study vector dot product calculations in physics
  • Learn about Newton's second law and its applications
  • Explore the concept of instantaneous power in mechanics
  • Investigate scenarios involving forces and motion in one dimension
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of force and power calculations in vector form.
critch
Hi, I've been trying to complete this question for almost an hour, i was hoping you could provide some advice
At a certain instant, a particle-like object is acted on by a force F = (5.0 N) i hat - (1.0 N) j hat + (10.0 N) k hat while the object's velocity is v = - (2.0 m/s) i hat + (4.0 m/s) k hat. 1)What is the instantaneous rate at which the force does work on the object?
2)At some other time, the velocity consists of only a j component. If the force is unchanged, and the instantaneous power is -12 W, what is the velocity of the object just then?
I tried taking the dot product of the force and velocity, making sure i only multiplied the like terms of the unit vectors. then i took the hypotenuse using pythagoras, but the answer i get is 41.2 Watts and its not right? please could someone help?
1) Taking the dot product is enough. I didn't quite understand what you have done after that.
2) Suppose the velo is v = vj. Find F.v and equate it to the instantaneous power given.
  • · Replies 24 ·
  • · Replies 25 ·
