Light pulse measurement with photodiodes
This discussion focuses on measuring high light pulses using photodiodes, specifically targeting light levels of 2-3W of irradiance with pulse widths ranging from 20µs to 1ms. The proposed design involves a reverse-biased photodiode connected to a voltage-to-current converting circuit to estimate power output based on the responsivity curve. Challenges include saturation of photodiodes at low levels and the need for effective attenuation methods, such as using crossed polarizers calibrated with DC light. Suggestions include utilizing a Thermal Power Meter for measuring average power and exploring circuit designs that synchronize with pulse triggers.
  • Understanding of photodiode operation and characteristics
  • Knowledge of voltage-to-current conversion circuits
  • Familiarity with light attenuation techniques, including polarizers
  • Basic principles of pulse width modulation and carrier lifetime in semiconductors
  • Research "Malus' Law" for effective light attenuation using polarizers
  • Explore the specifications and usage of Thermal Power Meters for high power measurements
  • Investigate advanced photodiode circuit designs for high-speed pulse detection
  • Learn about semiconductor carrier lifetime and its impact on photodiode performance
Engineers, researchers, and technicians involved in optical measurements, photonics, and high-power light pulse applications will benefit from this discussion.
jstamour802
I am trying to measure very high light pulses by using photodiodes. Light levels are expected to be upwards of 2-3W of irradiance.
Pulse-widths are from 20uSec to 1mSec. Example light source is a highly over-driven high brightness LED, typically 200-300mW in power (during recommended current levels)
My basic design is to have a reverse-biased photodiode fed into a voltage->current converting circuit. The pulsed light will excite the diode and the circuit should effectively convert voltage output from the diode to a current output so I can estimate the power output from the pulsed light by following a responsivity curve.
The problem is, I can't find a way to measure such high light levels with these devices. This is a very low-speed application, 10-20Hz. All the photodiodes I can find saturate at very low levels and I can only read low levels of power.
Anyone have any ideas?
Can you attenuate the light signal by some known amount? Use crossed polarizers at an angle that you set to a calibrated attenuation amount (using DC light to calibrate the attenuation amount).
jstamour802 said:
The pulsed light will excite the diode and the circuit should effectively convert voltage output from the diode to a current output...
From my understanding it is not entirely the "pulse" that excites the diode but rather the CW (continuous wave) component of your input that's exciting the diode. Thats why your diode is saturating. Most semiconductor diodes are rated up to several mW. The polarizer idea by berkeman is a good idea - utilizing something like "Malus' Law" :
See bottom of page: http://en.wikipedia.org/wiki/Polarizer"
Since your source is fairly broadband what about getting a Thermal Power Meter? They usually handle up to 3-4W. (Again measuring total average power)
I am currently trying to measure peak powers and have a thread:
https://www.physicsforums.com/showthread.php?t=221909
if that's of any interest keep watching, hopefully someone should have a good idea.
Indeed your pulses are fairly long compared to the carrier lifetime of a semiconductor diode, in which case you could probably come up with a (complicated) circuit using an input trigger from your pulse generator and only have the diode "looking" at the instants that a pulse hits the diode...I don't know how well that would work though.
  • · Replies 24 ·
  • · Replies 19 ·
  • · Replies 28 ·
