| Thread Closed |
Elastic Collision - Symbolic Question |
Share Thread | Thread Tools |
| Mar16-08, 10:57 AM | #1 |
Suppose you hold a small ball of mass m1 in contact with, and directly over, the center of mass of a large ball of mass m2. If you then drop the small ball a short time after dropping the large ball, the small ball rebounds with surprising speed. If we ignore air resistance and assume the large ball makes an elastic collision with the floor and then makes an elastic collision with the still descending small ball and that large ball has much larger mass than the small ball then: a) If the velocity of the small ball immediately before the collision is v, what is the velocity of the large ball? (in terms of v) b) What is the velocity of the small ball immediately after its collision with the large ball? (in terms of v) c) What is the ratio of the small ball's rebound distance to the distance it fell before the collision? (a number) 2. Relevant equations 1/2mv^2 + mgh = 1/2mv^2 + mgh Elastic collision: V1 = -V2 3. The attempt at a solution a. -V b. ? c. ? |
| Mar16-08, 11:23 AM | #2 |
Mentor
Hint: Analyze the problem in the center of mass frame, then transform back to the lab frame. (Assume m2 >> m1.)
| Mar16-08, 11:28 AM | #3 |
That...doesn't make a bit of sense to me. Pardon my lack of knowledge, but I'm not really familiar with the terms you were using, Doc Al.
| Mar16-08, 05:35 PM | #4 |
Mentor
Elastic Collision - Symbolic QuestionWhat do you know about elastic collision? Here's a hint for part b: If a ping pong ball hits a bowling ball, what happens to the velocity of the bowling ball? (To a good approximation.) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Elastic Collision - Symbolic Question
| question on impulse, does it assume elastic collision? | Introductory Physics Homework | 1 | ||
| Elastic collision question: two marbles | Introductory Physics Homework | 1 | ||
| Elastic collision | Introductory Physics Homework | 3 | ||
| Elastic Collision question | Introductory Physics Homework | 4 | ||
| Elastic Collision | Introductory Physics Homework | 1 | ||
