Kinematics of Rigid Bodies:Calculating Angular Velocity
The discussion focuses on calculating the angular velocity magnitude of member BC in a rigid body system. The key equations referenced are V = ωr and Va = Vb + Va/b. The radius at point C is specified as 0.4 m, which is essential for determining the momentary velocity of point C. The user seeks clarification on the interpretation of the slope indicated by "4|_ 3" in relation to member BC's position.
  • Understanding of angular velocity and its relationship to linear velocity
  • Familiarity with rigid body dynamics
  • Knowledge of relative motion equations
  • Basic geometry concepts related to slopes and angles
  • Study the application of the equation V = ωr in rigid body motion
  • Learn about the principles of relative motion in mechanics
  • Explore the significance of slopes in kinematic analysis
  • Investigate angular velocity calculations in various rigid body scenarios
Students studying mechanical engineering, physics enthusiasts, and professionals involved in kinematics and dynamics of rigid bodies.
pronep
What is the angular velocity magnitude of member BC?
Problem Figure Attached:
V = w r
Va= Vb + Va/b
I thought the problem would be simple as I could use v=w r to calculate the velocity and then use the equation of relative motion to calculate BC...But I am stuck trying to figure out the radius of the disc... Help please..
The full radius of the disk is not necessary. The radius at point C is given as .4 m. That with the angular speed gives the momentary velocity of point C. I'm assuming that the "4|_ 3" thingy is giving the slope of BC at that moment?
  • · Replies 17 ·
  • · Replies 40 ·
  • · Replies 32 ·
