Angular acceleration of the disk as a function of time
The discussion centers on the angular acceleration of a disk as a function of time, specifically a disk with a radius of 21.0 cm. The acceleration of a ball attached to the disk follows the equation a(t) = At, where A is determined to be 0.533 m/s². The angular acceleration of the disk is expressed as 2.54 rad/s³(t), and the time taken to reach an angular speed of 12.0 rad/s is calculated to be 3.07 seconds. The participant successfully resolved the problem after initially struggling with part d.
  • Understanding of angular motion and acceleration
  • Familiarity with kinematic equations
  • Knowledge of torque and its relation to angular acceleration
  • Basic principles of rotational dynamics
  • Study the relationship between linear and angular acceleration
  • Learn about torque calculations in rotational systems
  • Explore the concepts of moment of inertia and its impact on angular motion
  • Review kinematic equations for rotational motion
Students studying physics, particularly those focusing on rotational dynamics and angular motion, as well as educators looking for practical examples of these concepts in action.
iamwilson
A disk of radius 21.0cm is free to turn about an axle perpendicular to it through its center. It has very thin but strong string wrapped around its rim, and the string is attached to a ball that is pulled tangentially away from the rim of the disk (the figure ). The pull increases in magnitude and produces an acceleration of the ball that obeys the equation a(t)=At, where t is in seconds and A is a constant. The cylinder starts from rest, and at the end of the third second, the ball's acceleration is 1.60m/s^2 .
A) find A
B)Express the angular acceleration of the disk as a function of time.
c)How much time after the disk has begun to turn does it reach an angular speed of 12.0rad/s
Through what angle has the disk turned just as it reaches 12.0rad/s ? (Hint: See Section 2.6 in the textbook.)
i solved a, b, &c, I'm stuck on part d
for A, i got 0.533m/s^2, b)2.54rad/s^3(t), c)3.07s, d)?
for part d, I'm clueless on which formula to use
NVM, i figured it out
  • · Replies 40 ·
