Calculating Volume of a Pyramid Frustum with Square Base and Top
  • Thread starter Thread starter Lamoid
    Pyramid
The discussion revolves around calculating the volume of a frustum of a pyramid with a square base and a square top, defined by the side lengths of the base (b), top (a), and height (h). Participants are exploring the geometric properties and volume calculation methods for this specific shape.
  • The original poster attempts to apply integral calculus to find the volume but expresses uncertainty about how to adapt their usual methods for a shape with flat sides. Some participants suggest defining a function for the side length at varying heights to facilitate the integration process.
Participants are actively engaging in refining the function that describes the side length of the square at different heights. There is a productive exchange regarding the formulation of this function, with some guidance provided on ensuring it meets the necessary conditions at the specified heights.
There is an emphasis on understanding the linear relationship between the heights and the side lengths of the squares, as well as ensuring the function accurately reflects the geometry of the frustum. Participants are also questioning the assumptions made in their initial formulations.
Lamoid
Find the volume of frustum of a pyramid with square base of side b, square top of side a, and height h.
Usually when I do these volume problems, I treat them as an equation rotating around an axis, but this object has flat sides so I don't know how to begin.
http://upload.wikimedia.org/wikipedia/en/f/f8/Pyramid_frustum_for_Moscow_papyrus_14.jpg
The solid looks like that.
I know I need to make an integral from 0 to h of the area of the square but while I usually replace the radius in the formula with an equation, I cannot do so here.
Thanks in advance.
Yes you can: Let s(y) be the length of the side of the square at height y. You know that s(0) = b and s(h) = a. You also know that s(y) has to a linear function of y. (Why?) Use these facts to find s(y).
So S(y) is (a - b)x / h ?
I think you meant (a - b)y / h. You know this is not it because when y = h, it yields a - b. You want it to yield just a.
Oh whoop, I should have seen my linear equation needed a "+ b" on the end based on the 0,b point. So the equation should look like s(y) = (a-b)y/h + b ?
You got it.
11K
  • · Replies 20 ·
14K
  • · Replies 16 ·
9K
