Reducing turbulence through 90 degrees prob
  • Thread starter Thread starter engineering
    Degrees Turbulence
The discussion centers on the effects of a 90-degree pipe bend on turbulence levels in air flow, with a focus on designing internal bends to mitigate turbulence. Participants explore the relationship between turbulence, pressure changes, and flow dynamics in the context of fluid mechanics and HVAC engineering.
  • One participant inquires about the factors influencing turbulence when air passes through a 90-degree bend and suggests designing internal bends to reduce turbulence.
  • Another participant notes that turbulence arises from fluid viscosity and mechanical interactions, particularly in abrupt directional changes.
  • There is a discussion on whether "turbulence" is the correct term, with one participant suggesting that pressure drop across fittings is a more relevant concern for engineers.
  • A participant mentions the importance of understanding pressure changes in relation to air flow and density, referencing Bernoulli's equation.
  • Another participant emphasizes the need to reduce recirculation zones within the elbow, which contribute to pressure losses, and suggests using guide vanes to assist fluid flow.
  • One participant shares a personal experience regarding pressure loss in HVAC systems due to poorly designed fittings, highlighting the significance of proper design to minimize energy loss.
  • A participant provides a reference to a textbook that illustrates areas of flow separation and secondary flow induced by elbows.
Participants express differing views on the terminology and focus of the discussion, with some emphasizing turbulence while others prioritize pressure loss and recirculation. The discussion remains unresolved regarding the best approach to reducing turbulence and pressure loss in pipe bends.
Participants acknowledge the complexity of fluid dynamics and the importance of design considerations, but there are unresolved assumptions regarding the definitions of turbulence and pressure loss in the context of air flow through bends.
engineering
hello
I wanted to know what happens to the level of turbulence when air pass through a 90 degrees pipe bend (where in the bend turbulence is greatest). I want to design a pipe to reduce turbulence through 90 degrees. I know its obvious that level of turbulence increases but i am puzzled as to what influences it. I am designing bends inside the pipe which the air can flow to reduce turbulence. Wanted to know if anyone has any ideas or can help me?
Thank you
Engineeing
Turbulence is a consequence of the viscosity of a fluid and mechanical interaction with the boundaries, and in the case of elbows and fittings, the tumbling caused by abrupt changes in direction (acceleration).
I am only dealing with gases at the moment I assume your definition is still valid. My problem is reduction of turbulence in terms of air flowing through a 90 degrees elbow. Would introductions of internal bends be a way of reducing turbulence? Please view my sketch I apologize in advance for the sketch its v poor.
Thank you for response
Engineering
I'm not sure "turbulence" is really what you are looking for since fully developed flow is largely turbulent and "turbulence" isn't really a quantifiable property anyway. What engineers really concern themselves with is pressure drop across such a fitting. Have you studied much fluid dynamics?
In any case, the question you are asking is a critical one for HVAC engineering and as such it is well-researched and well understood. If you can, get a copy of the SMACNA duct design guidelines, they have highly detailed tables for predicting pressure loss through different duct configurations. This includes the use of the type of structures in your sketch: they're called "turning vanes".
Thank you for your reply
I have studied fluid dynamics. Why would pressure changes in the pipework be of importance? (by that i mean what happens to the flow of air at different pressures?) I think it may affect the density of the air traveling through bend but i am not sure. I understand that it maybe something to do with bernoulys equation, please elaborate
greatful for any help
thank you
engineering
Yes, as the pressure changes the density changes. In compressible fluid flow this is more apparent.
CS
Engineering
You're not looking at turbulence. You need to reduce recirculation inside the elbow. The two zones of recirculation are mostly responsible for the pressure losses. Usually guide vanes are put inside bends to help the fluid around the bend.
http://www.freepatentsonline.com/6668580-0-display.jpg
The pressure loss through elbows and fittings is the primary source of energy loss in most ductwork systems. It's what determines the energy required to move the required amount of air through the duct. When properly designed, it isn't much worse than the skin friction losses, but when a mistake is made (say, the contractor picks a bad aspect ratio for the elbow or doesn't use turning vanes), the energy loss is a real killer.
This past year, I did some troubleshooting on an HVAC system that wasn't meeting its required airflow. I found that fully half of the pressure lost in the entire system was lost in a single poorly conceived fitting.
Here is a scan from my text by Munson, Young and Okiishi. Look at the second page and note the areas of separation and the secondary flow induced. There is also another picture of an elbow with guide vanes installed.
Thanks for all the help guys much appreciated.
also cheers fred ill look over these two pages looks like interesting stuff thanks for taking the time to locate this information for me.
Engineering
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 19 ·
37K
