Conceptual Question on Net Torque
The discussion revolves around the effects of a constant nonzero net torque on various angular properties of an object, specifically exploring which quantities can be constant under these conditions.
  • Participants discuss the implications of changing angular position and angular velocity, questioning how these changes affect other quantities like angular acceleration, moment of inertia, and kinetic energy.
Some participants have provided reasoning regarding the relationships between angular quantities and have suggested that angular acceleration must also change if angular velocity is not constant. There is ongoing verification of answers, with multiple participants seeking confirmation of their reasoning.
Participants are working within the constraints of a homework problem, and there is a focus on understanding the relationships between angular properties without reaching a definitive conclusion.
klopez
A constant nonzero net torque is exerted on an object. Which of the following can not be constant? Choose all that apply.
-angular position
-angular velocity
-angular acceleration
-location of center of mass
-moment of inertia
-kinetic energy
My guess is that angular position and angular velocity can not be constant, but I'm not 100% sure. Can anyone help me here?
You are correct that the angular velocity and angular position cannot be constant but if those are changing, will some of the other quantities also change?
HINT:
If the angular velocity changes, what other option(s) will change?
I see, so according to the kinematics of angular properties, if angular position and angular speed is not constant, than that means that the angular acceleration is not constant either. The moment of inertia depends on Mass and distance from the axis, so since those are constants, the moment of inertia are constant right? And since kinetic energy (rotational) depends on moment of inertia (constant) and angular speed(non-constant), then kinetic energy is also not constant.
So this is my answer for the problem:
Angular Position
Angular Speed
Angular Acceleration
Kinetic Energy
Are all non-constants
***CAN ANYONE CHECK IF I'M CORRECT PLEASE?
THANKS
Why is angular acceleration not constant?
Do you know an equation relating angular acceleration, net torque and the moment of inertial.
Okay, so I think I should use this equation torque = I*alpha
Where alpha(angular acceleration) has to be constant because I is constant and the net torque is constant.
So therefore, my answer should be:
Angular Position
Angular Speed
Kinetic Energy
Are all non-constant.
Is this correct? Can anyone check this for me please?
Thanks
Can anyone confirm my answer above?
I agree with your latest answer.
  • · Replies 30 ·
  • · Replies 32 ·
