Recommendations for best SPICE package (especially convergence)
  • Thread starter Thread starter berkeman
    Convergence
The discussion revolves around the challenges of circuit convergence in various SPICE simulation packages, particularly focusing on DC convergence issues. Participants share their experiences with different tools and techniques to address these problems, including the use of nodesets and initial conditions.
  • One participant mentions a transition from Analog Workbench to a Windows-based SPICE package, highlighting ongoing convergence issues with certain circuits.
  • Another suggests using a nodeset or initial condition to aid convergence, but notes that this has only helped with transient analysis, not DC.
  • A participant asserts that providing a stable nodeset guarantees convergence, but questions arise about the nature of nodesets in relation to DC analysis.
  • Concerns are raised about the constraints imposed by nodesets during DC analysis, with a desire to release these constraints to observe true stable values.
  • Discussion includes the potential of using HSPICE and Spectre, with some participants sharing their experiences and preferences regarding these packages.
  • One participant describes a technique of temporarily removing parts of the circuit to create a nodeset that can help achieve convergence when the circuit is reassembled.
Participants express differing views on the effectiveness of nodesets and initial conditions for achieving convergence, indicating that no consensus exists on the best approach or the capabilities of specific SPICE packages.
Participants mention limitations related to the specific behavior of nodesets in different simulators, the need for realistic stimuli, and the challenges of using certain SPICE packages for Monte Carlo simulations.
berkeman
Admin
We used Analog Workbench on Sun UNIX workstations for many years here at work, but transitioned to a Windows-based SPICE package about 8 years ago. The package has worked reasonably well, and we have gotten great technical support from the vendor.
However, we are facing some especially vexing convergence issues with some circuits that we are re-simulating (they worked fine on Analog Workbench many years ago), and I was looking for input from other power-SPICE users out there about SPICE packages that you use and have found relatively free of convergence issues (especially DC convergence). Or, if you have run into convergence issues, and your SPICE package has enough hooks and handles to help you to get the simulation to converge and start.
Thanks for any input. I'm not mentioning which package we're using because of the good technical support we have gotten over the years -- they just haven't been able to help with this particular circuit's convergence problem.
Try using a nodeset or initial condition before trying to move to another simulator.
- Warren
- Warren
Yeah, done that. It helps for the Transient analysis, but not for DC. We're getting a feedback oscillation around the actual value, but this package doesn't let us decrease the step size in the convergence process to a small enough value to help the convergence along...
What package do you use, Warren?
We have HSPICE too for more IC design work, and haven't tried this circuit yet because of the clunky HSPICE interface (we probably will at some point), and because we aren't set up for Monte Carlos with HSPICE.
It doesn't matter. If you can give the simulator a nodeset with a stable solution, then you've gauranteed convergence. End of story. If you gave it a nodeset and it didn't work, then you gave it a nodeset that wasn't actually a solution. Try again.
I mostly use Spectre.
- Warren
I spoke more with the engineer who is encountering this problem, and he says that for the SPICE package we are using, when you use nodeset for a DC analysis (we're doing Monte Carlos to check variations of DC operating points at the moment), that constrains the value of that node for the whole process, not just for the intial stabilization and convergence. But we want to be able to let go of that node at some point, to see what its real final stable value is, not just the other nodes with that node constrained artificially. For Transient analysis, the nodesets are released once the initial stable operating point is acheived.
Do you know if Spectre allows the nodeset to be released at some point in the DC analysis? Pretty pricey SPICE package! BTW, the engineer having this issue has used Spectre a fair amount in the past at another company, and he said that in general, he did not have many convergence problems with the latest versions of that package.
There may be some differences between a "nodeset" and an "initial condition," then, in your simulator. I'm not suggesting that you fix nodes to any specific values for the duration of a simulation, only that you provide the simulator with a specific, desired solution so that convergence can be effectively skipped. Look into .ic and other such commands.
Also, make sure that all your stimuli are physically realistic. I've seen many people apply power supplies with zero rise-time and wonder why it doesn't converge...
And yeah, Spectre's pricey, but we're an analog design house. Carpenters need hammers.
- Warren
Another, more invasive technique is to remove parts of the circuit that are causing convergence issues, run a .dc and store the result as a nodeset. Then you can put the circuit back together, and use that nodeset as an initial condition for most of the circuit, and that's often enough to allow the simulator to converge to only one specific solution.
- Warren
