Can the Integral of Sin[x^2] Be Expressed in Exact Form?
  • Thread starter gamesguru
  • Tags
    Integration
In summary: FunctionIn summary, the function is used to calculate the intensity of light as it diffracts off of a surface.
gamesguru
85
I've attached my work, but basically, I'm trying to compute this:
[tex]\int_{0}^{\infty}2\sin({x^2})dx[/tex].
(The 2 is only there because when you expand it into an exponential function, it makes like easier.)
You can look at my work to see what I did. My question now is, is it possible to express that limit in exact form? If so, what is it? Why does the limit have this value?
http://img358.imageshack.us/img358/7304/file0004ch0.jpg
I also tried doing this with double integrals and polar coordinates to calculate the square of the integral but I ran into a problem deep into it of evaluating [itex]\sin{\infty}[/itex] and [itex]\cos{\infty}[/itex].
If you're curious why I care about this, it's because this integral is important in the diffraction of light. While only the approximate answer is important in physics, I'm just curious about the mathematics behind it.
Thanks in advanced.
It has no elementary anti derivative so it can't be evaluated in a closed form, but you can only get a pretty good approximation, as you have done
Hi gamesguru! :smile:
(1) 1.2533 = √(π/2).
(2) Do you know the trick for integrating [tex]\int_{0}^{\infty}e^{-x^2}dx[/tex] ?
Try putting [tex]\int_{0}^{\infty}\sin{x^2}dx[/tex] = imaginary part of [tex]\int_{0}^{\infty}e^{i x^2}dx[/tex]. :smile:
(or perhaps [tex]\lim{\epsilon\to0}\int_{0}^{\infty}e^{(i\,-\,\epsilon) x^2}dx[/tex], for positive real epsilon)
@tiny-tim
I tried that method, read my post. I got to a point where I was evaluating cos[∞] or sin[∞]. Try it for yourself, it won't work.
gamesguru said:
@tiny-tim
ah … I must have stopped reading the post when I started looking at the .jpg, and then forgotten where to resume reading. :redface:
Yup … that's why I suggested the epsilon method.
(I haven't actually checked it myself … but the result is right, so I expect it works … over to you! :smile:)
I don't see how the epsilon method makes this more easy to integrate. I'd appreciate it if you should me how to do it, or at least get started.
Because you end up evaluating [tex]e^{-\epsilon x^2} e^{i x^2}[/tex] from 0 to ∞ (which converges), instead of just [tex]e^{i x^2}[/tex] (which doesn't). :smile:
In, [tex]e^{-\epsilon x^2} e^{i x^2}[/tex] the first term goes to 1 (e^0=1), not 0. I still don't see how this helps...
Yes, but e^-∞ = 0, which is what matters! :smile:
[tex]
e^{-\epsilon x^2} e^{i x^2}=e^{-0x^2}e^{ix^2}=e^{ix^2}
[/tex]
...what am i missing? I don't see a [itex]e^{-\infty}[/itex].
ah … in my post #7, I was talking about x going from 0 to ∞.
I thought you had already found that that was the problem … that e^(ix^2), or sin(x^2), doesn't converge as x -> ∞.
But multiply it by e^(-(epsilon)x^2), where epsilon is fixed, and it converges to 0. :smile:
I'm not sure I follow you. I'd really like it if you just do it so I could see how it's done and possibly learn something. We're making no progress right now.
1. What is the general formula for the integration of Sin[x^2]?
The general formula for the integration of Sin[x^2] is given by:
∫ Sin[x^2]dx = √(π/2) * erf(x/√2) + C, where erf is the error function and C is the constant of integration.
2. Is there a specific method for integrating Sin[x^2]?
Yes, there is a specific method for integrating Sin[x^2] known as the Fresnel-C integral method. This method involves using the Fresnel integrals and can be used to find the definite integral of Sin[x^2] over any interval.
3. Can the integral of Sin[x^2] be solved analytically?
No, the integral of Sin[x^2] cannot be solved analytically in terms of elementary functions. It can only be solved using numerical methods or approximations.
4. What are some applications of the integration of Sin[x^2]?
The integration of Sin[x^2] has applications in various fields such as signal processing, Fourier analysis, optics, and quantum mechanics. It is also used in solving differential equations and evaluating definite integrals.
5. Are there any useful properties of the integration of Sin[x^2]?
Yes, there are some useful properties of the integration of Sin[x^2] such as the fact that it is odd, meaning that ∫ Sin[x^2]dx = -∫ Sin[x^2]dx. Additionally, it has a repeating pattern of values when integrated over consecutive intervals of π, making it useful for calculations in certain scenarios.
  • Calculus
  • Calculus
