How can I solve a multiloop circuit using Kirchhoff's laws?
  • Thread starter Thread starter gills
    Circuit Kirchhoff
The discussion revolves around solving a multiloop circuit using Kirchhoff's laws, specifically focusing on determining the currents I(1), I(2), and I(3). Participants are exploring the application of Kirchhoff's current and voltage laws in the context of circuit analysis.
  • Mixed
  • Participants discuss various methods for analyzing the circuit, including the use of node and loop equations. Some express uncertainty about the necessity of certain current labels and the complexity of their approaches. Others suggest alternative methods, such as simplifying the circuit or using Gaussian elimination for solving systems of equations.
The conversation includes multiple interpretations of the circuit setup and the equations derived from it. Some participants have provided guidance on refining the equations and suggested dropping certain currents to simplify the analysis. There is an ongoing exploration of effective methods for solving the resulting systems of equations.
There are indications of missing labels in the circuit diagram, which some participants have noted as potentially complicating the analysis. Additionally, participants are navigating the constraints of homework requirements while attempting to understand the problem better.
gills
What is the current in I(1), I(2), and I(3)?
At nodes [tex]\sum[/tex]I = 0
Loops [tex]\sum[/tex]V = 0
Ok, I'm definitely new to this multiloop stuff so I'm not quite sure what the best way to work these problems is.
Here's what i have for nodes:
I(4) + I(6) - I(5) = 0
I(2) - I(4) - I(3) = 0
I(1) + I(3) - I(6) = 0and loops:
12 - I(4)5 + I(6)8 - 9 + I(1)1 - I(2)1 = 0
12 - I(3)10 - 9 + I(1)1 - I(2)1 = 0
9 - I(6)8 - I(1) = 0
12 - I(4)5 - I(2)1 = 0Any help on the best and easiest way to work these would be great. Thanks
Are there labels missing on the diagram. I(4), I(5), I(6)
they aren't on the diagram. I just ended up putting them in myself because it seems like i would need them. However, i probably overcomplicated it as i always tend to do. Do i even need an I(4), I(5), and I(6)?
IMO the most efficient way to solve these is the following method.
1. replace series and parallel resistances (doesn't work in this one)
2. give an arbitrary point a potential of 0. I'd take the node in the middle here between
the four resistances. If you need an equivalent resistance, call the 2 connections to the circuit 0 and V.
3. guess the potential at all points where more than 2 wires meet and call them V_1, V_2 etc. There are two such points here
4. use ohms law to work out all currents as a function of these potentials.
5. Use kirchhof's current rule in each of the points from step 3. This will give you as
many equations as unknowns.
6. Now that you found the potentials, compute the currents you need.
The loop rule is completely redundant here.
Though kamerling gives an excellent approach, there's nothing wrong with your original method using nodes and loops. For this problem I would use three independent loop equations (because I see three loops) and two node equations.
Since your I(5) just runs through a piece of bare wire, I would not have defined it. (You can always shrink a bare wire down to a point.) Thus I would only have 5 currents and thus only need 5 equations.
I would just drop your first equation. (Forget I(5).)
and loops:
You really only have three independent loops. Your first equation is just the sum of the last two (or it should be--you have some errors).
So I would drop your first equation. The last two need to be corrected: You have the sign in front of the I(1) and I(2) terms wrong.
Once you have your corrected 5 equations, it's just a matter of turning the crank. 5 equations and 5 unknowns. Start by eliminating one variable--I(4) say--in all your equations. Then eliminate another--I(6) say. And so on until you've solved for one of the currents. Then go back and find the others.
Ok, I've rewritten my equations and my diagram because I've made the wire in between a node where there's no component like you said.
nodes:
I(2) - I(3) - I(5) = 0
I(1) + I(3) - I(4) = 0
loops:
12 - 5I(5) - I(2) = 0
9 - 8I(4) - I(1) = 0
12 - 10I(3) - 9 + I(1) - I(2) = 0
5 eq, 5 unknowns. Unfortunately (and fortunately ;)) I've plugged these into MATlab to check and see if it would be right and it was:
I(1) = 0.848
I(2) = 2.14
I(3) = 0.171
However, i need to try and solve these on my own. What is usually the most effective way for systems of equations, substitution or elimination? Just such a tedious task...
Thanks Doc and everyone else
While I'm sure there are clever ways of solving systems of equations (using matrix methods or whatever), I suggest using the simple method of Gaussian elimination. Just systematically eliminate the variables until you have one left. Keep all your intermediate equations, since once you get one value you'll be able to quickly get the others just by plugging in.
Tedius? You bet! Get busy. :smile:
thanks Doc. Tedious indeed, but i got it.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 31 ·
