| Thread Closed |
Error calculations involving gradients |
Share Thread |
| Mar31-08, 10:09 PM | #1 |
I'm trying to work out the percentage error in working out the value of gravity,g, from a pendulums motion.
i know that percentage error is (possible error/value used)*100 however im using multiple values multiple times and its getting a little confusing. In the investigation g=k(∆Tē/∆L), my problem is that i have the error for working out T which is 0.001 seconds. The error in L is 0.001m. As i'm using a difference of two values for each of the ∆'s would i double each error and for the error of Tē would i square 0.001 and then double it. any explainations would be helpful Thanks ∆Tē=2.112 ∆L=0.51 |
| Mar31-08, 10:24 PM | #2 |
Recognitions:
You know that
[tex]T=2\pi \sqrt{\frac{l}{g}}[/tex] so that [tex]T^2=4\pi^2 \frac{L}{g}[/tex] and that means that [tex]g=\frac{4\pi^2}{T^2}L[/tex] To find the error you do this. [tex]\frac{\delta g}{g}=2\frac{\delta T}{T} + \frac{\delta L}{L}[/tex] [itex]\delta T[/itex] would be the error in T and similarly for [itex]\delta L[/itex] is the error in L. |
| Thread Closed |
Similar discussions for: Error calculations involving gradients
| Measurement error analyses, fitting min/max slopes to data with error bars. | Set Theory, Logic, Probability, Statistics | 2 | ||
| Help with drawing gradients along error bars! | Introductory Physics Homework | 1 | ||
| Can someone tell me what error calculations to do | Advanced Physics Homework | 1 | ||
| help with error calculations. | Introductory Physics Homework | 5 | ||
| Involving Errors In Calculations | Introductory Physics Homework | 4 | ||
