What is the true statement about Carnot engine efficiency?
The discussion revolves around the efficiency of a Carnot engine, specifically evaluating various statements regarding its characteristics and principles. Participants are analyzing the validity of multiple-choice options related to thermodynamic concepts.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are attempting to eliminate incorrect options based on their understanding of thermodynamics. Questions are raised about the definitions of reversible and irreversible processes, as well as the implications of the second law of thermodynamics on engine efficiency.
There are multiple interpretations of the statements, with some participants suggesting further research on Carnot engines and the differences between reversible and irreversible processes. A variety of viewpoints are presented, but no consensus has been reached regarding the correct answer.
Participants mention the absence of equations and express uncertainty about the definitions and implications of the statements provided in the question. The discussion reflects a need for deeper understanding of thermodynamic principles without providing definitive answers.
newyork
Which of the following statements about a Carnot engine is true?
a) Any Carnot engine has an efficiency of 100%
b) Irreversible energies have the greatest possible efficiency.
c) Heat can spontaneously flow from a cold reservoir to a hotter reservoir.
d) If a process is reversible, the efficiency of an engine is maximum.
e) All energies are reversible.
None
Well, I think the answer is E. I canceled out choice b because no where in my textbook did it mention irreversible energies having high efficiency. I don't think it's choice a because the third law of thermodynamics says reaching a temperature of absolute zero is impossible and makes it impossible for a Carnot cycle engine to achieve 100% efficiency. So if I'm right, why is E right? If I'm wrong, then why would it be one of the other choices? I pretty much just used process of elimination.
i suggest you to check much better the differences beetween rev and irrev process.
regards
regards
i've got a better idea. research what a carnot engine is. it's a lot faster than checking the differences between rev and irrev processes. it will actually help you solve the question
i think the answer is that all engines are reversible. the one that states that "if a process is reversible, the efficiency of an engine is maximum" wouldn't be accurate because ALL processes have to be reversible to obtain maximum efficiency, not just one.
I would say d is the correct answer here, a is completely false due to the second law of thermodynamcs(never can all heat be converted into pure work),b is obviously not true, c would not have a positive entropy change andhence does not occur spontaneously, e doesn't make sense...hence my choice d, however the statements are rather ambiguous
15K
