Calculate the change in potential energy
The discussion revolves around calculating the change in potential energy of water as it descends over Niagara Falls, including related questions about energy conversion and household electricity supply. The subject area includes gravitational potential energy and power calculations.
  • Participants discuss the calculation of potential energy using the formula mgh and consider the implications of positive and negative values. There are inquiries about the rate of energy loss and the relationship between work and power. Some participants explore the definitions and relationships between force, work, and power without plugging in specific numbers.
The discussion has progressed with participants sharing insights and calculations. Some have arrived at specific numerical answers, while others are still exploring the underlying concepts and relationships. There is a collaborative atmosphere with participants offering guidance and prompting further thought.
Participants mention constraints such as limited attempts for the assignment and the need for careful consideration of calculations. There is also a focus on ensuring understanding before finalizing answers.
killa0587
1. (a) Calculate the change in potential energy of 1.8 kg of water as it passes over Niagara Falls (a vertical descent of 50 m).
______ J
(b) At what rate is gravitational potential energy lost by the water of the Niagara River? The rate of flow is 5.5 106 kg/s.
______GW
(c) If 27% of this energy can be converted into electrical energy, how many households would the electricity supply? (An average household uses an average electrical power of about 1 kW.)
______Households
on a i tried m*g*h but got the incorrect answer
a. 882
Is this a web assignment? Have you tried a negative value?
yeah it is. I thought about the negative but only have one attempt left and want to be really sure about it
Think about it. At the very top you have a lot of potential energy, and at the very bottom you have no potential energy if your zero point is the ground. The change in something is always the final minus the initial. Knowing this, what should your change in potential energy be then?
the -882J
and that was it...Thanks!
any insight on the others maybe just to get me started?
What is the rate of energy, or work? It is power. What is the work done by the fall? Don't plug any numbers in yet, though.
well work is force x displacement correct
so the displacement would be the length of the fall
What's the force then?
1.8 x 9.8=17.64whats GW though?
gigga watts
No numbers yet, mate. I just want you to know what the force was. But good, you know that F = mg
Now then, you also noted that W = mgd.
With just variables, what does P (power) equal to?
power = work / time or
p= mgd / t
Alright, so you've got [tex]P = \frac{mgd}{t}[/tex]
But they give you [tex]\frac{m}{t}[/tex] in the question, so just solve away.
Sweet! So I got 2.7 GW
And on the last part I would take the 2.7GW and convert to kW then multiply by .27
Thanks So much I got all 3 of them correct.
10K
  • · Replies 49 ·
