| Thread Closed |
Energy density of electric field |
Share Thread | Thread Tools |
| Apr8-08, 01:02 PM | #1 |
Assume that 10% of the energy dissipated by a 40W light bulb is radiated isotropically in the form of light. What is the magnitude of he E-field at a distance of 1m? What is it for sun light on the Earth's surface, given the Sun provides ~ 1400W/m2> 2. Relevant equations Energy density = 1/2[tex]\epsilon[/tex][tex]_{}0[/tex]E[tex]^{}2[/tex] 3. The attempt at a solution Ok so I know that we have 4W available, but how do I convert this into and energy per unit area on the surface or volume? I assume we have to use the equation for the energy denstiy of a magnetic field given above. |
| Apr8-08, 01:27 PM | #2 |
If it spreads out isotropically in all directions, then the power [4 W] is uniform at any point on the sphere of the radius, and can be given by:
[tex] I = \frac{1}{\pi}~Wm^{-2} [/tex] You have the same thing i.e. Intensity for the 'sun' question. Now, Intensity is simply: [tex] I = \frac{Energy \times velocity}{Volume} [/tex] so.. i guess i've given u enough hint now.. [at what velocity does e.m energy travel?] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Energy density of electric field
| Electric field inside a sphere of charge density A/r | Introductory Physics Homework | 4 | ||
| Electric Field and Charge Density | Introductory Physics Homework | 10 | ||
| The Electric Field of a Ball of Uniform Charge Density | Advanced Physics Homework | 5 | ||
| [SOLVED] Electric Field and Charge Density | Introductory Physics Homework | 0 | ||
| Electric Field Energy Density | Advanced Physics Homework | 1 | ||
