Calculating Volume of Finite Region Using Multiple Integrals
The discussion focuses on calculating the volume of the finite region between the surfaces defined by the equations z = x² + 4y² and z = 2x + 8y + 4. The initial approach involved setting up a double integral but encountered complications due to complex bounds. A suggested method involves substituting variables to simplify the problem, specifically using X = x and Y = 2y, leading to a symmetric paraboloid. Further simplification with new variables X' and Y' allows for easier intersection calculations.
  • Understanding of double integrals in multivariable calculus
  • Familiarity with surface equations and their intersections
  • Knowledge of variable substitution techniques in integration
  • Experience with Jacobians in coordinate transformations
  • Study the method of variable substitution in multiple integrals
  • Learn about Jacobians and their application in changing variables
  • Explore the concept of volume calculation between surfaces using double integrals
  • Investigate the properties of symmetric paraboloids and their intersections with planes
Students and educators in calculus, particularly those focusing on multivariable integration, as well as anyone needing to solve complex volume problems involving surfaces.
joker_900
Hi, I've been trying this for days now and I really can't get it, so would appreciate some help please!
Find the volume of the finite region between the two surfaces z=x^2 + 4y^2 and z=2x + 8y + 4
I tried to do a double integral of (x^2 + 4y^2 - 2x - 8y - 4)dxdy. I thought the bounds of this on the x-y plane would be given by x^2 + 4y^2=2x + 8y + 4. However doing this gives a nasty quadratic for x in terms of y that makes things impossible. I'm also pretty sure I need to sub in something of the form x=a*r*cosP, y=b*r*sinP. The Jacobian for this would be abr.
I got thie bound to be between x=1-[5+8y - 4y^2] and 1 + [5+8y - 4y^2] and y = -0.5 and 5/2
I think this is wrong!
I tried subbing in the sin and cos things also, but don't know how to work out the bounds.
Please help!
Think, what is the shadow of z=x^2 + 4y^2 in the xy-plane?
joker_900 said:
Find the volume of the finite region between the two surfaces z=x^2 + 4y^2 and z=2x + 8y + 4!
Hi joker_900! :smile:
(btw, feel free to copy ² and anything else you like for future use. :smile:)
Now, this isn't the best way of doing it … but when ever I get confused, I try to simplify the problem as much as possible … it may take a little longer … but that's better than being completely confused! :redface:
I would make the substitution X = x, Y = 2y.
Then we get a nice symmetric paraboloid, z = X² + Y², intersecting the plane z = 2X + 4Y + 4.
And then I'd simplify again by putting X´ = X + 2Y, Y´= 2X - Y (so they're perpendicular, and we have 5z = X´² + Y´² intersecting z = 2X´ + 4).
Does that help? :smile:
  • · Replies 27 ·
