| Thread Closed |
chemistry: buffers and pH |
Share Thread | Thread Tools |
| Apr9-08, 03:04 PM | #1 |
A mixture containing 500ml of .1 M HC3H5O2 (acetic acid) and 500 ml of .1 M NaC3H5O2 what is the pH? 2. Relevant equations can someone walk me through this? i know the answer is 4.89 but im not sure how to get that. im not even entirely sure how to set up the equation 3. The attempt at a solution i tried this to start, but not sure if its right: notations: wa = weak acid sa = strong acid wb = weak base sb = strong base n = neutral -wa----sb-------wb-----n HAc + NaOH <> NaAc + H20 even if this is right, im not sure where to go from here. |
| Apr9-08, 03:18 PM | #2 |
Have you studied the Henderson-Hasselbach equation?
| Apr9-08, 03:40 PM | #3 |
Just curious but are you provided with the Ka (acid dissociation constant) value for HC3H5O2?
For this case it's [salt] over [acid] (with Henderson-Hasselbach equation). Notice the acidic buffer there. |
| Apr9-08, 04:01 PM | #4 |
o sorry, the Ka = 1.3 x 10^-5
and yes we were taught the enderson-Hasselbach technique i wish i could edit that into the 1st post but w/e |
| Apr9-08, 04:07 PM | #5 |
pH = pKa + log10 [salt]/[acid] pKa = -log10 (Ka) It's that simple =) Try it out! You don't even have to write out the equation. NaC3H5O2 is the salt and HC3H5O2 is the acid. What you do need to know is that this is an acidic buffer solution. |
| Apr9-08, 11:48 PM | #6 |
ah ok that was easier than i thought, thanks
| Thread Closed |
| Thread Tools | |
Similar Threads for: chemistry: buffers and pH
| Buffers - Titrations | Biology, Chemistry & Other Homework | 1 | ||
| how does one prepare a 100ml of a 0.1M sodium phosphate buffer? | Biology, Chemistry & Other Homework | 6 | ||
| determine the pKa value from the titration curves | Chemistry | 2 | ||
| Chemistry Buffers | Chemistry | 2 | ||
| Chemistry Buffers Theory !!! | Introductory Physics Homework | 1 | ||
