What is the derivative of the equation for volume?
  • Context: Undergrad
  • Thread starter Thread starter stuckie27
The discussion revolves around finding the derivative of an equation related to the volume of a geometric shape, specifically a combination of a cylinder and a hemisphere. Participants explore different methods of differentiation, including the quotient rule and simplification techniques.
  • Homework-related
  • One participant asks for the derivative of the expression \(3\pi r^2 + \left(\frac{2,000,000 - \frac{2}{3}\pi r^3}{r}\right)\) and inquires about the use of the quotient rule.
  • Another participant suggests that the expression can be simplified to \(\frac{7}{3}\pi r^2 + 2 \times 10^6 r^{-1}\) for easier differentiation.
  • A participant confirms the use of the quotient rule but expresses uncertainty about their arithmetic, providing a complex derivative expression.
  • Some participants emphasize the importance of simplifying the expression before differentiation to avoid complications.
  • One participant expresses frustration about the perceived triviality of the problem, while another counters that it may not be trivial for everyone.
  • A later reply provides a detailed breakdown of the volume and surface area equations for a metal storage tank, including steps to isolate variables and compute derivatives.
Participants do not reach a consensus on the best approach to differentiate the expression. There are competing views on whether to use the quotient rule or to simplify the expression first. Additionally, there is a divergence in opinions regarding the complexity of the problem.
Some participants express uncertainty about their calculations and the clarity of the expressions presented. The discussion includes various assumptions about the methods of differentiation and the context of the problem.
stuckie27
Smiple Equation.
What is the derative of 3pi*r^2+ ((2,000,000-(2/3pi*r^3))/r)
Do you use the quotient rule
It'd work, but it's more work than you need to do.
That same expression can be written as
[tex]\frac{7}{3}\pi r^2 + 2\times 10^6 r^{-1}[/tex]
which can be differentiated easily.
cookiemonster
Yup you use the quotient rule. This is what I got when I did (warning, I am prone to make arithmetic mistakes)
[itex]6\pir + \frac{ r (\frac{18/pir^2}{3/pir^5}) –(2,000,000 – (\frac{2}{3\pir^3}){r^2}[/itex]
I agree, which is why you should simplify the expression before differentiating it.
cookiemonster
Thanks for the quick reply.
3 cookies for cookiemonster (extra choclate chip)
how did you simplify the equation?
sigh... waste of good time on these trivial problems...
Distributed the r^(-1) in the second term and then combined coefficients of like powers of r.
And a trivial problem to you, Ebolamonk3y, may not be trivial to somebody else.
cookiemonster
What is this? \frac{ r (\frac{18/pir^2}{3/pir^5}) Its not in my original equation
use [tex]...[/tex]
Any reason for this comment?
Is this not a calc help forum?
I can write you the full prolbem if you would like to solve the whole thing.
Here It is
A metal storage tank with a volume of 1000 liters is to be constructed in the shape of a right cylinder surmounted by a hemisphere. What dimentions will require the least amount of metal?
It's supposed to be the expression for the derivative of your original expression. I think. I can't read it well enough to really know, though.
cookiemonster
Let's not turn this into a flame war, okay?
cookiemonster
Well... long time ago I proposed this huge problem that I made up for a friend of mine... by the end of it I noticed that the problem didn't led to anywhere but a handful of arithemetic exercises... And that doesn't serve any purpose, I am not udnersetanding more just because I did some rote problems... It was some derivative involving the chainrule and this stuff where there is so many layers and functions of functions that one get lost it in and finally one wonders, what is this for? Waste of time for me... So that's why I said that... Take no offense, that is how I felt about my experience...
Like... if one wants to really find antiderivated to e^(x^2)... because one didn't read about it, one this they can use some stuff on it and then they realize... :(
Sorry about that.
[sarcasm] But… but… my brain can beat up your brain [/sarcasm]
heh. perhaps. my mind is afflicted with many things like depression to easily succumb to an incoming invasion of anothers mind. :p
Lets start from scratch.
The volume is the sum of the volume of a hemisphere and a cylinder.
[tex]V= \frac 2 3 \pi r^3 + \pi r^2 h[/tex]
The surface area is
[tex]S= 2 \pi r h + 2 \pi r^2[/tex]
Isolate h in the Volumn equation.
[tex]h = \frac {V- \frac 2 3 \pi r^2} {\pi r^2}[/tex]
plug into the Surface area equation.
[tex]S= 2 \pi r \frac {V- \frac 2 3 \pi r^2} {\pi r^2} + 2 \pi r^2[/tex]
[tex]S= \frac {2 V} r + \frac 2 3 \pi r^2[/tex]
Compute the derivative.
[tex]\frac {dS} {dr} = - \frac {2V} {r^2} + \frac 4 3 \pi r = 0[/tex]
Solve for r
[tex]-2V + \frac 4 3 \pi r^3 = 0[/tex]
[tex]r^3 = \frac {3V} {2 \pi}[/tex]
Complete by solving for h.
  • · Replies 16 ·
