Determine the magnitude of the current in the circuit
The discussion focuses on calculating the current and voltage in a circuit using Ohm's Law. The current (I) is determined to be 0.3846A by applying the formula I = (30V - 10V) / (27Ω + 5Ω + 8Ω + 12Ω). The voltage between points A and B (Vab) is calculated as +19.6158V, indicating that point B is at a higher potential than point A.
  • Understanding of Ohm's Law
  • Basic circuit analysis skills
  • Familiarity with voltage and current concepts
  • Knowledge of series circuit components
  • Study advanced circuit analysis techniques
  • Learn about Kirchhoff's Voltage Law (KVL)
  • Explore the use of multimeters for measuring current and voltage
  • Investigate the impact of resistance on circuit performance
Electrical engineering students, hobbyists working on circuit design, and anyone seeking to improve their understanding of basic electrical concepts.
dedra73
This is a problem I had for homework. I want to make sure I did it correctly.
http://i90.photobucket.com/albums/k256/dedra73/circuit-2.jpg
(a) Determine the magnitude of the current in the circuit and
I = (30-10)V / (27+5+8+12)Ω
=20V/52Ω
=.3846A
(b) The magnitude of the voltage between the points labeled A and B.
Vab = 30V - .3846A * 27Ω
= 30V- 10.3842V
= +19.6158V
(c) State which point, A or B, is at the higher potential.
Point B is 19.6158V higher than A
Looks good to me!
  • · Replies 49 ·
  • · Replies 31 ·
