| Thread Closed |
Simulatenous Conservation of Momentum and Conservation of Energy |
Share Thread | Thread Tools |
| Apr14-08, 09:42 PM | #1 |
Say I have three wheels. Their characteristics are the following:
WHEEL ONE 20 kg mass 10 cm radius Accelerated from 0 to 10 m/s in one second WHEEL TWO 10 kg mass 20 cm radius Accelerated from 0 to 10 m/s in one second WHEEL THREE 10 kg mass 10 cm radius Accelerated from 0 to 20 m/s in one second We assume all wheels are close enough to uniform mass density and that their moment of inertia is calculated according to (mass*radius^2), the case for a cylinder. The values above were specifically chosen so that the final angular momentum for all three wheels are the same. We now determine the rotational kinetic energy for all three wheels. WHEEL ONE 20 kg mass 10 cm radius Accelerated from 0 to 10 m/s in one second Angular Momentum = 20 kg*m/s^2 Final Rotational Kinetic Energy = (1/2) * (20 kg * (10 cm)^2) * ((10 m/s)/(10 cm))^2 = 1000 Joules WHEEL TWO 10 kg mass 20 cm radius Accelerated from 0 to 10 m/s in one second Angular Momentum = 20 kg*m/s^2 Final Rotational Kinetic Energy = (1/2) * (10 kg * (20 cm)^2) * ((10 m/s)/(20 cm))^2 = 500 Joules WHEEL THREE 10 kg mass 10 cm radius Accelerated from 0 to 20 m/s in one second Angular Momentum = 20 kg*m/s^2 Final Rotational Kinetic Energy = (1/2) * (10 kg * (10 cm)^2) * ((20 m/s)/(10 cm))^2 = 2000 Joules Consider that angular momentum was transferred from one wheel to the other. Apparently what I said suggests that the rotational kinetic energy does not follow a one-to-one relationship with angular momentum. What other forms of energy should be present in this scenario? |
| Apr15-08, 09:29 AM | #2 |
Mentor
> "What other forms of energy should be present in this scenario?"
Heat. This is similar to linear momentum problems involving collisions between different masses. Linear momentum is conserved. But kinetic energy is either conserved (elastic collision) or reduced (inelastic), with the lost kinetic energy converted to heat. p.s. FYI, units of angular momentum are kg*m^2 / s, as seen from the equation (moment of inertia) x (angular speed) = (kg*m^2) x (1/s) |
| Apr15-08, 11:59 AM | #3 |
How about regular kinetic energy? You say you set it up so they would have the same angular momentum at the end, that means that they're all traveling at different speeds. So (1/2) M V^2 where v is the center of mass.
| Apr15-08, 03:21 PM | #4 |
Mentor
Wow, I didn't even think of translational kinetic energy. I interpreted the description as the wheels were stationary but rotating, and the given speeds were just the speed at the wheels' rims. But yes, if he meant that the wheels were moving translationally as well as rotating, regular kinetic energy has to be accounted for too.
| Apr15-08, 11:59 PM | #5 |
| Apr16-08, 06:15 AM | #6 |
Mentor
To simplify the picture, think of a ball swinging around on a rope. Imagine the rope is being drawn in while the ball circles around; the ball's path is then an inward spiral. There is work done on the ball because the angle between rope tension and the ball's direction is not 90 degrees (as it is for purely circular motion), so the work formula: W = F x D x cos(angle) is nonzero. |
| Apr22-08, 03:13 PM | #7 |
1) The significance, if any, of F x D? 2) The significance, if any, of F x D minus the work done on the ball? 3) The significance, if any, of F x D x sin(angle)? 4) The significance, if any, of F x D x sin(angle) plus the work done on the ball? |
| Apr22-08, 03:33 PM | #8 |
| Apr22-08, 10:00 PM | #9 |
Mentor
F x D x cos(angle) and this equals the work done on the ball when it travels a short distance D in its trajectory. See the included figure. Pulling in on the rope results in a non-zero value for the cos(angle) factor, so that work is done on the ball. The work increases the kinetic energy, and thus also the velocity of the ball. How much does the velocity increase by? By exactly enough so that angular momentum is conserved!
| Apr24-08, 10:31 PM | #10 |
Request to explain as to how to start on these subjects.
The bearing calculations, FEA, bearing design etc. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Simulatenous Conservation of Momentum and Conservation of Energy
| conservation of momentum vs conservation of kinetic energy | Introductory Physics Homework | 18 | ||
| Law of the Conservation of Angular Momentum > Principle of Conservation of Momentum | General Engineering | 0 | ||
| Conservation of energy or conservation of momentum | Introductory Physics Homework | 2 | ||
| Conservation of momentum (with conservation of energy) | Introductory Physics Homework | 1 | ||
| Conservation of Momentum and Energy | Introductory Physics Homework | 2 | ||
