Indirect and direct band gaps in silicon
  • Context: Graduate
  • Thread starter Thread starter Aun-shi
    Band Silicon
This discussion focuses on the band structure of silicon, highlighting that bulk silicon exhibits an indirect band gap due to the separation of the highest occupied valence band and the lowest unoccupied conduction band at different k-values. It is established that reducing the size of silicon structures, such as in quantum confinement, transforms the indirect band gap into a direct band gap. Factors influencing this phenomenon include lattice parameters, crystal symmetry, and the nature of the orbitals involved, which are critical in determining the material's band structure.
  • Understanding of band theory and electronic structure
  • Familiarity with silicon crystal structures
  • Knowledge of quantum confinement effects
  • Basic principles of solid-state physics
  • Research the electronic structure of silicon using density functional theory (DFT)
  • Explore the effects of quantum confinement on semiconductor materials
  • Study the band structure of transition metal dichalcogenides (TMDs) like MoS2
  • Investigate the role of lattice parameters and crystal symmetry in determining band gaps
Researchers in materials science, physicists studying semiconductor properties, and engineers involved in nanotechnology and electronic device fabrication will benefit from this discussion.
Aun-shi
Hi
This semester my group and I are calculating the band structure of silicone (bulk and nano crystals).
In bulk silicon a indirect band gap occurs, where the highest occupied valence band and the lowest unoccupied conduction band are situated at different k-values.
Does anyone know why this actually happens? If you have some literature that gives a valid explanation I would appreciate it.
Another interesting thing is when quantum confining silicon structure the indirect band gap becomes direct. Does anyone know why reducing the size of silicon result in a more direct band gap? Also here if anyone has some literature that explains it I would appreciate it.
Thanks!
There isn’t a single reason for why some materials have a direct band gap and others have an indirect band gap. The lattice parameters, crystal symmetry, and nature of the orbitals involved will all play a role in determining the band structure of the material, and I doubt there’s an easy way to tell whether the gap will be direct or indirect without explicitly solving the electronic structure.
That said, you are correct that geometry and particle size can play a role in band structure. A very famous recent example is MoS2, which has a layered structure. A single layer has a direct band gap whereas 2 or more layers stacked in their native rhombohedral state have an indirect gap.
